Question about Dell PowerEdge 2600 Server
When the server turn on the monitor couldn't display anything
My friend has given the server to me several days before. The server has not been used for long time, when it turn on, the monitor can't display anything and there is an orange light blinking.
I need your second opinion/suggestion for this problem.
thank you for your attention&suggestion.
There could be several issues causing the problem. I am presuming the blinking orange light is on the monitor which usually indicates there is no video signal. So, the first thing I would do is re-seat the video card if it has one. The second thing would check would be the CMOS battery, verify that there is over 3.0v. After that if neither of these two things has fixed the issue more information would be required. What make is the motherboard, what is the processor, etc.
Posted on May 10, 2008
No display on screen
Several things to be checked -
Does the monitor work on another computer?
Have you tried both video ports - front & back?
Can you get into BIOS with the appropriate key ("Del" or "F2") and does this show a screen?
Can your monitor display the native resolution of the server?
There are various links below which you could use to find out more about the problem ;-
http://www-947.ibm.com/support/entry/portal/product/system_x/system_x3550_m3?productContext=-208896503
or
http://www-947.ibm.com/support/entry/portal/product/system_x/system_x3550_m4?productContext=1269965189
or
http://public.dhe.ibm.com/common/ssi/ecm/en/xso03094usen/XSO03094USEN.PDF
or
http://www.redbooks.ibm.com/technotes/tips0804.pdf
If you still cannot get a display to show on your monitor, then the bad news may be that either the graphics component on the motherboard, the motherboard itself, the memory or the CPU may have given up the ghost. First see if you can get a compatible graphics card that you know works fitted into an expansion slot and see if that will give you a screen. Otherwise one by one replacement of the components may be the only option.
Dec 01, 2013 | IBM System X3550 Server
I HAVE A PHILIPS 50"
Unfortunately this would be uneconomical to repair due to the price of the plasma display panel. Your best option would be to look on eBay for a faulty set with working pdp
Feb 07, 2011 | Philips 50PFP5332D 50 in. Plasma...
There are three servers (2 G5s and 1 G4) these servers share a single monitor but i don't use any kvm switch.. I manually switch the connection of the monitor to access the three servers. i use G4 most of...
Do you try disabling Screensaver feature on those two servers...might that be causing display prob, if you try pressing any key or it would show screen
But still if it is not working, Check Power saving feature for these two Server, turn off featue to turn off display and harddisk if computer is standy by for......mins
Hope it resolve issue, Best of Luck
Oct 09, 2009 | HP ProLiant DL360 G5 (457922-001) Server
My ACER AL1916 blinks several times before picture is displayed when the monitor is turned-on for the first time in the early morning and stays stable all day. I connected it using VGA cable. Any...
Usually this happens when the monitor is trying to translate the signal given off by the video card.
Nothing to worry about, simply a process that the system needs to go through.
If this solution has helped you, please take the time to rate me.
Oct 04, 2009 | Acer AL1916W 19" LCD Monitor
My 42" flat screen wont turn on
ok is this a lcd, cause what your friend said is bs. Did you install anything on that day? did you uninstall anything? or did it randomly shut down on you
Aug 31, 2009 | Dell E153FP 15" LCD Monitor
Monitor and keyboard will not respond
It only happens with your keyboard and mouse? or does it include your monitor too? if it does include you monitor then it is the video card. It is built in to your system and is causing the problem. I got the same issue before. My mouse doesn't work, keyboard won't respond, monitor is blank. I know its the video card. It is not typical for a server to respond that way but you need to replace the system or replace the video card...
Dec 10, 2008 | Dell PowerEdge 2300 Server
No video at all on Compaq ProLiant 1850R
Do the server has an onboard Video disable the video in the BIOS setup insert another PCI Video card and check for the display , IF the PCI display is up then there could be a problem with Onboard card.
Nov 27, 2008 | HP Compaq ProLiant 1850R Server
Powers up temporaly displays goes dark
Your monitor has a bad back light. Send it back to your friend
Nov 22, 2007 | BenQ T705 17" LCD Monitor
Dell PowerEdge 2600 Server Logo
804 people viewed this question
Alun Cox
