Question about Compaq Armada E500 Notebook
How can I adjust brigthness using other option than F9, because it does not work
In my compaq armada e500 with winXP does not work F9 and F10 options, how can i fix it, or how can i modyfy brigthness.
thank you
    New Friend:
I had the same problem, i pressed F10 and i waited for 10 mn then a boot screen occured.i used exit button and it does work correctly.
Posted on Jun 03, 2013
  • 3,940 Answers
Per the user manual, the brightness is toggled by holding the Fn Key and pressing F10. You post made no reference to the Fn Key being pressed. If using an external keyboard press scroll lock twice then F10.
Reference: http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01124713/c01124713.pdf
Posted on May 10, 2008
I need help on restoring my compaq armada e500
Hi Welcome to FixYa!
You could try these steps on restoring your laptop into its factory defaults.
1)Turn off your computer if it is on. Wait for the system to shut down completely. Once it is off, press the "Power" button to turn it back on. Press the "F10" button at the top of the keyboard repeatedly as soon as you see the screen turn on. This will let you enter the setup menu.
2)Use the arrow keys to move between the various menu tabs at the top of the screen. Press the "Right" button until the "File" tab is highlighted, then press the "Enter" button to enter this menu. Here you can make changes to the settings of your computer, or in this instance, restore factory default settings.
3)Use the "Up" and "Down" arrow buttons to move to the "Restore Defaults" option, then press enter. You will see a screen asking "Are You Sure You Wish to Restore System Defaults?" Press the "Y" button to continue. The system will begin restoring your default settings. Do not press a button until a screen says "System Defaults Restored."
4)Use the arrow keys to move down to the "Save Changes and Exit" option and press "Enter." The system will save your changes and automatically reboot your computer. You do not need to press "F10" this time as the computer will start Windows normally. You will see the factory settings have been restored once the system loads.
Hope this could help!
  • Jul 07, 2011 | Compaq Armada E500 Notebook
    How to enter in the bios
    Press F10 just after powering the PC, to access BIOS of your Compaq Armada E500 Notebook.
    GoodLuck!
    Dont forget to appreciate the solution if I could have been of any help!
    CreativeTECH
    Dec 07, 2010 | Compaq Armada E500 Notebook
    My armada e500 will turn on, do the little compaq sign then just stay on a blank screen and won't do anything further. HELP!!!!
    Try draining the flea power first:
    1. Remove the battery and ac adapter
    2. Press and hold the power button for at least 10sec.
    3. Put back the battery and ac adapter
    4. Turn on the computer
    Check if it will load to windows, if not, there could be a problem with windows. Try startup repair on advanced boot options. Hope this helps.
    May 13, 2010 | Compaq Armada E500 Notebook
    How do you adjust britness on the screen?
    You can adjust the armada's screen brightness by pressing the "Fn" key and F10 key simultaneously. If this helps FixYa, please share the love and let me and others know by providing a bit of feedback. Happy Computing!
    Mar 27, 2010 | Compaq Armada E500 Notebook
    Installing Ubuntu on Compaq Armada E500.
    NO all system is low spec. low memory, Hd, cpu,and so on, you might upgrade memory to above 256M to run Winxp and use the orignal driver cds, for driver req. as win98 or NT driver, 1st try upgrade memory, and test.
    Jan 02, 2010 | Computers & Internet
    My usb port of my Compaq Armada E500 Laptop no
    the usb port of my hp Compaq Laptop nc6000 no longer works properly. whenever i insert a flash it says usb device not recognized.
    Jun 03, 2009 | Compaq Armada E500 Notebook
    Compaq armada e500
    you can safely install up to a 80 GB HDD in that compaq. When getting into the bios go to the boot sequence section and change the boot squence to be CD=>HDD=>FLOPPY or FLOPPY=>CD=>HDD
    Jun 02, 2009 | Compaq Armada E500 Notebook
    My laptop displays nothing when switched on.
    I have the smae laptop as u and this hapend to me, what i acidently did was hold down the Fn button and press f10 . To get ur display back up do the same thing Hold down Fn and press F10
    hope this helps :)
    Feb 16, 2009 | Compaq Armada E500 Notebook
    Compaq armada e500
    The key for bios is F10 just press during compag loading screen or if dat doesnt work immeditely after. I found this out by trying all of them in sequence to see which one worked
    Jun 09, 2008 | Compaq Armada E500 Notebook
    My compaq Armada E500 wont come on
    Replace hdd couse the pc dont recognize hdd..First go to the bios and load optimal default or optimized default and pres F10 and restart
    If it wont work just buy NEW HDD
    Oct 19, 2007 | Compaq Armada E500 Notebook
    Compaq Armada E500 Notebook Logo
    375 people viewed this question
    Top Compaq Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
