Question about Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228
My pool pump is licking there was only on washer i changed , but did not helped
    Novelist:
  • 116 Answers
I think you need to clarify.... Do you mean "clicking" instead of "licking", and what washer did you change?
Posted on Sep 18, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Pumps manuals
if calcium deposits seals leaking replace pump
Sep 29, 2013 | Hayward Max - Flo 1 1/2 - Hp In Ground...
How to change the seals on a jacuzzi magnun force 1 hp pool pump
If you haven't already figured out how to change the seals on your Jacuzzi Magnum Force pump, I can help by supplying a diagram.
Here is the parts explosion for that pump.
Start by removing the case/basket assembly, then the diffuser to get to the impeller. Loosen the impeller to get to the seal plate.
When going to the trouble of changing the shaft seals one should change all the hosing seals at the same time because its a lot of work.
Jul 02, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
My ao smith 1.5 hp pool pump is leaking. A washer about an inch round popped off and is cracked and broken. I dismantled pump and took off the 4 long screws to get to the washer. At this point I'm trying...
BUMMER THE IMPELLER IS BROKE U WILL NEED A NEW ONE. USE TWO BIG SCREW DRIVERS AND PRY TO BREAK THE IMPELLER.. THERE IS NUMBERS ON THE IMPELLER USE THESE TO GET THE RIGHT IMPELLER FOR YOUR HP MOTOR REMEMBER TO VOTE FOR YOUR FAVORITE FIXIT GUY ! THANKS JAY
Jun 21, 2010 | A.O. Smith SQ1102 Pool Pump Motor
No power
The following link explains how to replace the drain pump on a Whirlpool Duet:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
If you have questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water is leaking from under washer
it a simple thing to fix look at this video it will teach U how to fix the leaking problem.
washer lick fix by kids
http://www.youtube.com/watch?v=UQ0HElQlhNA&NR=1
Please let me know if this solve your problem. Was this helpful? your rate is very important to me thank you
Aug 28, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I have a stack whirlpool dryer and washer that is about 15 yrs old never had a problem, but now washer is licking water from underneath..please need help or suggestion.. thnk you
Suggesting from the pump or a deteriorated hose.
I am thinking safety first as water and electricity don't mix so I would certainly have it inspected by a repairman as a matter of urgency. You do not want to be electrocuted or have a fire.
Sep 14, 2008 | Whirlpool Washing Machines
Emerson THREADED SHAFT UP RATED - 1.00 HP - EB228 Logo
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Mike Squire
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
