Acer 2416W monitor comes on for 1 second then goes black
    Problem Solver:
  • 19 Answers
Try a different monitor
could be video card problem
best if can try a known good one
does power light stay green and hd light flash like activity continues, can you boot in safe mode, if so might be video driver , also looked for popped capacitors on mb , if computer actually goes off try a know good power supply
Posted on Sep 02, 2010
Acer X193W Monitor comes on correctly, but after about 3 seconds it goes black. Can turn off & back on & get the same result.
the problem is not with your monitor the problem with your cpu which is not providing the signal that's why it goes off
Mar 04, 2013 | Acer X193W LCD Monitor
Monitor comes displays Acer logo and goes black after 3 seconds, with indicator light still green.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 18, 2010 | Acer AL1916W 19" LCD Monitor
When switched on screen is live for about 1 second then goes black
My flat screen monitor does not light up. Could it be a burned bulb>
Oct 18, 2010 | Acer V193w LCD Monitor
Acer LCD monitor goes black after 1 second
More likely to be bad caps (bulging top), look for that first, the caps may be out gassing, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 21, 2010 | Computers & Internet
Screan comes on for 1 second then goes black. switch light showes recieving signal.
This Acer 2416w has problems with weak capacitors on the inverter board causing shorting of the driver FETs. Replacing caps and shorted FETs may solve the malfunction.
Monitor Mike
Oct 04, 2009 | Acer AL2416W 24 in. LCD Television
The screen goes black ACER Aspire
I have the same problem with my Acer 5684 laptop. Just bought display backup light (CCFL) from ebay. Hopefuly will arrive within next 5-10 days. I will let you know if this solves it.
Sep 30, 2009 | Acer AL1914 19" LCD Monitor
Power supply on 17" acer monitor
franh, Typical of a lcd/fpd monitor! There is nothing you or hundreds of others can do to repair it all by yourself. I have repaired 3 monitors and helped tutor 2 others on fixya with their monitors. All had same exact symptom as your monitor. I need you to do a simple test for me. With failed Acer monitor near to your Fully Booted PC with a known good desktop being displayed on back-up monitor, quickly swap out the monitor cables from the back of the PC. Keep touching the CTRL key on you keyboarb every 30-50 seconds to keep the PC from sending out sleep mode command to monitor while doing the reconnect of acer to your PC monitor output port. Make sure the Acer also is connected to a live wall outlet/power strip. Turn on the Acer and note what happens. If screen shows a sharp clear image for a second, then goes black, do the following. Get a bright flashlight and shine it on the screen from a distance of 1 or 2 inches and tell me if you can see the desktop display. get back to me with your observations. I'm louie12fix on fixya or lmistyrel@ aol.com.
Apr 05, 2009 | Acer AL1916W 19" LCD Monitor
Monitor goes to black and back on
MY LCD 22 ACER MONITOR GOES O BLACK AND I CAN'T SEE THE MENU
Nov 21, 2008 | Acer 22" X223w LCD Monitor
Computer Monitor
hmmm chek the power board in the back chek resistors and ic's in ocilloscope good luck
Oct 12, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
