Question about Microsoft Windows Xp Home Edition English International for PC
Help!i have reinstalled windows and...
Whn i have reinstalled windows, i thought my computer is empty, but in the disk drive C and D there are my old documents! and all of them work, but there are no programs installed.
  • NickFixYou
    NickFixYou May 10, 2008
    in disk clean up, what programs i select?
    Problem Solver:
  • 22 Answers
Goto to start and then programs then go to accessoreis then system tools then disk clean up.
rate for me if it works out
Posted on May 10, 2008
I ca not perform the delete deleted items action , not enough space in local disk?
Find some other files to delete or move onto a flash drive to make some room. Make sure your recycle bin is empty.
Jan 11, 2014 | Microsoft Office Professional 2007 Full...
I have 1 problem hp intel atom,whn switch on very very slow and blue screen blank,sum1 help me plssss!!!!
You need to run the Check Disk Utility but I think you have a netbook that does not have a CD Drive. Lesson learned the hard way.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Without a cd drive you might have to just do a System Recovery which means you will lose all your data.
Apr 25, 2012 | Computers & Internet
Hi I've got this problem with my Acer Apires laptop "a disk read error occurred, press ctrl+alt+del to restart. I keep pressing those buttons and the same things come over and over again what should...
Hi
that seems your computer cant boot from hard disk '
you can solve it by :
- be sure that nothing in cd drive and there's no flash memory in notebook.
- when you press start button , click F2 to enter set up and go to boot options and assign the first boot to Hard disk drive.
- if that don't help try to repair your windows ... or re install it
- final may be your notebook hard drive corrupted.
I hope that helps you
Apr 25, 2011 | Acer Aspire One PC Notebook
Virus in my computer will nnt let me startup please help my email is iva.corley5@gmail,com
Download DRWEB Cure It save to a USB stick, boot to safe mode (F8) and run the programme from the usb stick
Feb 12, 2011 | Computers & Internet
I can not reboot my Dell Studio XPS 1645 running Windows 7, because everytime I try reboot my computer the Windows Dianostics Utility keeps on starting up. I tried to use my Windows 7 installation...
Sounds like you've tried everything except a complete reinstall. If there is information you need off that computer the hard drive will need to be taken out and plugged into another PC as a second hard drive then all can be copied. Then try a complete reinstall and good luck with that. If any problems doing a reinstall i would look at the ram. Cheers from Scott and plz vote
Nov 03, 2010 | Dell Studio XPS 1645 Laptop
I have a autorun.inf virus in my cimputer that disable my task manager and regedit. please help me!!
Remove the disk-drive from your computer.
Attach it as a "slave" disk-drive in a different computer that has up-to-date anti-virus software installed.
Run the anti-virus software, targeting "all" the files on that "slave" disk-drive,
if you believe that it is possible for any anti-virus software to remove 100% of any computer-virus.
Or, read: http://technet.microsoft.com/en-us/library/cc700813.aspx
which describes "best practises", namely to copy all your data files, "flatten" the disk-drive,
reinstall Windows, and reload your data.
Or, take this incident as an "opportunity" to install a new (larger? faster?) disk-drive into your computer, disconnecting the old disk-drive, and to reinstall Windows,
and to install an anti-virus software package.
Then, temporarily attach the old disk-drive as a "slave" drive, and copy all your files.
When the copy completes, FORMAT the "slave" disk-drive, to wipe-out ALL the files on that disk.
Nov 02, 2010 | Computers & Internet
To Whom it may concern: MY GOAL IS TO BLOW AWAY THE ENTIRE DELL VOSTRO 1000 INTERNAL DISK AND REIMAGE USING ORIGINAL CD'S SENT WITH ORIGINAL PURCHASE. BACKGROUND: Wife's PC was running slow and I...
Start the computer.
Select the "old" system, and then repeatedly press F8,
until you see the Windows Start-Up Menu (white text over a black background).
Choose Start In Safe Mode with Command Prompt.
At the command-prompt, enter 'FORMAT C:' to "wipe" 100% of the files from the disk-drive.
When it completes, turn the computer off.
Turn the computer on, and boot from those original "System Restore" CDs.
It will load Windows onto your now-empty disk-drive.
Oct 24, 2010 | Computers & Internet
Windows xp pro will not boot with new hard drive
Its hard to tell just like this without having the computer in hand to check and test the jumpers and connection and all, but quick like this i think it might be a trojan virus that corrupted the boot sectors of the old hard drive, and when you copied the stuff from the old to the new, the virus followed and infected the boot sectors of the new one too. Try to reformat completely using the original windows install disk, and not the system restore/reinstall disk and reinstall windows after the format with the original windows disk again. If I was right, it should boot up OK with a fresh format and reinstall with the real windows CD, then install a virus scan and a spyware scan and scan and clean the old drive completely 2 or 3 times to be sure theres nothing bad left on it, then try to copy the whole disc, but skip the Windows repertory, the Program Files one too and the Documents and settings one also, cause those 3 are the ones most prone to corrupting a fresh install even if there is not any viruses in them. If it does not boot up OK after formating and reinstalling Windows though and says it's unbootable, then either there is a config error in the BIOS of the laptop, or the IDE controller that drives the disk is defective. If it's the BIOS settings, it's gonna be easy enough just changing the settings and won't cost you too much, and if its the IDE controller... then that's another story cause it's integrated in the motherboard like any other computer, so basically another computer will cost less than a new motherboard for a laptop. So if that is the case and the IDE controller is shot, you can still try to use an external USB drive to run the computer but not all computers support booting from the USB though, so before buying a brand new external drive, check the BIOS first to see if it does support USB booting.
Jul 08, 2009 | Compaq Evo N610C Notebook
After i have reinstalled windows, i have a problem
you should have formatted the drive first before you installed windows. But then you need all of the software drivers. XP is good, but not that good with drivers.
The files you are looking for will not be in add and remove.
May 10, 2008 | Microsoft Windows XP Home Edition
I have the Windows 98 disk not have lost the key codes, I am trying to reinstall this onto a new hard drive with no operating system so I can then upgrade to windows xp, help anyone?
You don't need a windows 98 disk to install XP. It will load directly from your Cd drive. You have to set the bios to be the first boot disk. It is much easier to install XP on an empty drive than to upgrade.
Apr 18, 2008 | Computers & Internet
Microsoft Windows Xp Home Edition English International for PC Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
