Question about GE Kitchen Ranges
GE Electric Profile range: Display shows a red F7 & a blinking green E6 What does this trouble shooting code mean ? Thank you in advance ror your help Jack Orlando, Fl.
  • 503 Answers
F7 is a stuck key. Usually you can't get a key unstuck. Best thing to do is replace the keypad / user interface. Here are some of GE's error codes:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Sep 02, 2010
Receiving F7 error code while cooking turkey model # GLEFM397
FIXED GE Profile Oven F7 error messages - ApplianceBlog
www.applianceblog.com/.../2655-GE-Profile-Oven-F7-error-messages
Jan 13, 2006 - 10 posts - ‎2 authors
My GE Profile built in convection/thermal wall oven constantly flashes F7 errormessages. ... Three of my neighbors and I have the same GE profile double oven (new home development) and we've all have the same problem as you described-F7. ... GE Oven F7 error message solution. LG Electric oven not heating. F7 error code
Jun 9, 2015
FIXED Kenmore Double Oven error code F0 and F7
Aug 31, 2010
More results from www.applianceblog.com
Nov 14, 2015 | Frigidaire Kitchen Ranges
GE Profile 30" slided in range/oven. Ran standard
shut down the power to the machine,disconnect the touchpad ribbon,turn the power back on and let it sit for a day,if the code comes back you have a bad board,if it doesn't come back you have a bad touchpad
Apr 02, 2011 | GE Profile 30" Self-Cleaning Slide-In...
What does fo mean? & how do I fix it?
Hello there
here is the code it can also show up as a f-7on the display but both of the fo codes and the f7 codes mean the same
F0 or F7 Shorted Clear/Off Key due to membrane switch, control or connector Shorted key panel membrane switch; Check Electronic Range Control (ERC)needs to be replaced ok?
695128 Price
$185.20 In Stock?
Yes Qty
Aug 05, 2010 | GE Profile JGS968SHSS Gas Kitchen Range
GE range displaying codes F7 E6, unable to turn oven on.
F7 E6 shows that Function pad button stuck or Bad clock try to Unstick Button or Replace Clock also if persist then check the connections to the contol panel
Oct 18, 2009 | GE Kitchen Ranges
F7 Code on my GE Profile Oven
Jun 17, 2009 | GE Profile JTP18 Electric Single Oven
The lcd scrren on my range displays F7 in red and flashes d6 in g
The code is because of bad keypad/the control panel.Have it changed.It probably non-functional and constant beeping sound is followed as you mentioned.Theres a link to explain more about this for reference.The only solution is to replace the control panel.
http://www.askgene.com/2007/06/23/oven-error-codes/ge-oven-error-code-f7-and-how-to-fix-it/
Dec 13, 2008 | GE Spectra JBP78 Electric Kitchen Range
Panel is showing f7 and flashing e6 57 56 58 5a
GE
Code
Dec 01, 2008 | GE Profile 30" Self-Cleaning Slide-In...
I have an GE oven and the display is showing F7 and flashing E6
F7 normally means there is aproblem with the key panel. Many times it needs to be replaced.
Sep 22, 2008 | GE Kitchen Ranges
Control panel shows F7 and contantly alarming or beebing
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Oct 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
186 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
