Question about Maytag Refrigerators
I have an older Maytag refrigerator model RSW24EOKU and need to replace a light bulb in the top shelf but can't locate.
    President:
  • 1,891 Answers
Can't locate what ? if it the size of the bulb use a 40 w appliance light . very standard . and if this does not ans problem tell me more of what is going on .. mm
Posted on Sep 02, 2010
How do I replace Maytag freezer light
You will need to post your model number. Thanks
Feb 01, 2015 | Maytag Refrigerators
Where is the water filter located in Maytag fridge and how do I replace it?
It is in the top refrigerator shelf behind that plastic shild. Take the shild off and I think that model is just a quarter turn and the little cylinder comes out
Jan 28, 2015 | Maytag MZD2766GES Side by Side...
Change light bulb in Maytag MAN1956GE Refrigerator. Can't loosen bulb. Can't remove plastic "cage" around bulb.
Hello Jane;
My name is Peter. I am a retired field service refrigeration technician.
What you have provided is the standard manual number not the model number. The model number is on a label on the inside wall of your fresh food section near the top.
You may have a single screw holding the light cover on.
Note; the bulbs in a refrigerator like all of you appliances is specially designed for the service. They are a little expensive $8.00 - $10.00 each. Some food markets carry them. If not Lowe's or Home Depot.
Go into the following link put in your model number and a diagram will appear to help you.
Water Filters Lawn Garden Appliance Parts
Dec 12, 2014 | Maytag Refrigerators
GE side by side refrigerator main light bulb stays on even when door is shut firmly.
There is a switch just inside the door in most on the roof of the fridge, make sure it is not damaged.
Jul 02, 2017 | Refrigerators
My 19 year old kitchenaid kbrs21k refrigerator still works fine BUT when i recently crammed too much stuff onto the top shelf i must have broken the plastic light cover which fell on top of the light bulb....
Take the bulb out and check the continuity. Then you should know if there is a fuse that needs replacing. If all is well make sure your new bulb doesn't have a bad element.
Dec 03, 2013 | KitchenAid KBRP20EMSS Bottom Freezer...
Light does not come on when you open door
Test your 40 watt light bulb in another fixture if the light bulb is OK then unplug the refrigerator and open fresh food compartment and pry out the light switch. Test for continuity HERE For some reason your model shows an additional light switch on the control panel located inside the fresh food compartment above top shelf. Try switching the ligh switch on from there. Here is a Photo Click HERE Here is a replacement light switch=> Light-Switch-2149705-00557365 If you have any questions I will be here to answer them for you, Thanks Sea Breeze
Feb 16, 2012 | Whirlpool Gold White-on-White 21.9 cu. ft....
How to change light bulb in refrigerator
Unplug the Whirlpool refrigerator from the electrical outlet.
Step 2
Locate the bulb on the inside of the Whirlpool refrigerator.
Step 3
Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
Step 4
Unscrew the old light bulb.
Step 5
Screw in the new light bulb.
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
Jul 29, 2010 | Whirlpool GX5FHTXVA Bottom Freezer French...
Maytag refrigerator lights won't work
the bulbs may look good but try a new one or just try tighting them into the sockets tighter. this is a common problem . the rubber prevents the bulb from going in all the way .. silcone grease on the bulb base.. mm
Dec 03, 2009 | Maytag MSD2756G Side by Side Refrigerator
I need to replace the adaptive Defrost Control Board on Maytag Refrigerator Model No. MZD2766GEQ. Where is this board located?
Its Located in the top right inside corner of the refrigerator section near the back wall & to the right of the water filter.Its tough to get out but only takes about 10 minutes to replace the part
Nov 18, 2009 | Maytag MSD2756G Side by Side Refrigerator
The food freezes in the refridgerator section
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Jul 11, 2009 | Maytag MTB1954EE Top Freezer Refrigerator
    Refrigerators Logo
    64 people viewed this question
    Top Maytag Refrigerators Experts
    Bailey's...
    Bailey's...
    Shehu Pro
    Shehu Pro
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
