Question about Sport & Outdoor - Others
Need a 1998 Fleetwood Pace Arrow RV chassis manual
  • 659 Answers
SOURCE: Hot Water Heater in 1991 Pace Arrow RV is not working
If you look on the outside of the RV, you will find the vent for the water heater behind and access door. There usually is a drain plug and valve located as well. Generally they will be tucked away under the kitchen sink area with internal access as well. You will need to find where the valve that shuts the water off to the unit is and turn it on. Most times the water heater is either electric or propane. But sometimes they are only propane. Once your find the access door, you will know where the water heater is. You can also contact Fleetwood who makes the Pace Arrow to see if they have any information on your unit. Usually your unit info or trim number will be located on a little plaque right by the entrance to the RV. You will need this when you contact them. Hope this helps.
Posted on Mar 31, 2009
SOURCE: busted solenoid for icemaker
got info free
Posted on May 26, 2009
shadtremonky
  • 353 Answers
SOURCE: cant depress brake caliper to replace pads
disc brakes on the rear of a vehicle have a screw out mechanism that attaches to the ebrake . this means that you must turn the caliper piston to recess into the cylinder.
open the bleed screw to make it move eazier.
Posted on Sep 21, 2009
Testimonial: "thanks for "bleed valve" tip. I had to take the whole caliper off due to debris in the chamber,the brakes have not been maintained prior to me."
Ironfist109
  • 3018 Answers
SOURCE: 83 Fleetwood Pace Arrow (454 Chev chasis) front
  • Below is a diagram of the wiring diagram of the heater/AC fan
  • As you can see there is a fuse and a relay that would be the first two suspect.
  • If you have any comments please feel free to leave them here and I will respond to you.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Sep 17, 2011
  • 5 Answers
SOURCE: Where can I obtain a chassis wiring diagram for a 1984 Pace Arrow Class A Gas RV
Chilton or Haynes make pretty good manuals and usually have a pretty comprehensive section with wiring diagrams. Not sure if either one of these companies have ever made a manual for your vehicle. Fuel-Saver.org has a selection of free wiring diagrams, again not sure if they have one for your particular vehicle. Hope this helps.
Posted on Aug 08, 2012
How to id 74 pace arrow motor
Look at the motor builder not at the RV section, Louis
Aug 24, 2016 | RVs
Why wont the parking brake release on my 1988 pace arrow motorhome ford chassis ?
As a mechanic II would have a look at the manual before trying to move it.
Jul 10, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
Fleetwood motorhome manual
The battery compartment for your Seabreeze Motorhome is located under the entry steps to your RV. Open the door to your RV grab the first step and lift up and you will find the house batteries and chassis battery in that compartment.
- See more at:http://www.xcardiag.com/search/?q=battery+
Feb 09, 2014 | Vehicle Parts & Accessories
Need a Wiring Diagram for a Radiator Condenser Fan which shows how to locate the Relay and Switch for a 1996 Fleetwood Pace Arrow Vision RV P30
I would call fleetwood out of nappannee Indiana a lot of times they use a special wiring using the A.C systems they install
Sep 18, 2012 | Cars & Trucks
Aug 08, 2012 | Cars & Trucks
Where do i find a manual for a 97 37ft pace arrow? or a least the specs for gas and holding tanks?
The only place you are likely to find a manual for a Pace Arrow is from the manufacter. Although ebay does sometimes have Pace Arrow manuals for sell on it.
Jul 01, 2011 | Ford F-450 Cars & Trucks
I bought a used 1984 pace arrow on a chevy chassic, while checking out the wiring I have found so many wires attached to the fuse box and other wires, I am trying to find a wiring diagram for both the...
you will have to contact pace arrow if still in business for the 120 volt wireing.they are all pretty much the same in similar years motor home so generic rv how to manuel would be ok.contact chevrolet for a cab and chassis manuel. as a side note, on the 120 volt system the black wire is not a ground.it is the hot wire.the white wire is nutral[ground] the 12 volt stuff is color coded like a 1984 chevy
Jun 07, 2010 | 1989 Cadillac Fleetwood
Recently purchased and did not come with owners manual and want to learn the trailers accomidations
You can order a Fleetwood Owner's Manual by sending a check or money order for $8.00 to the address listed below. If you require a chassis manual, you can contact the chassis manufacturer directly.
Fleetwood Service & Training Center
PO BOX 1007
Decatur, IN 46733
May 25, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Mar 31, 2009 | Water Heaters
Sport & Outdoor - Others Logo
77 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
