Question about Kenmore 22422 Top Load Washer
Kenmore Elite 110.22974100 usually over fills no matter what the water level setting is
  • jonathanm4 Sep 02, 2010
    Likely the water level sensor. I assume there is a valve for hot and a separate valve for cold. If neither shuts off, must be the sensor? Can I find this part by searching for "water level sensor" at Sears parts direct?
  • 11,896 Answers
There is a water level sensor in these machines that can go bad and let the machine overfill. Another possible cause could be the water valves are not shutting off completely. This could be due to a stuck valve or the water level sensor.
Posted on Sep 02, 2010
Kenmore elite oasis washer will fill with water and skip the wash cycle. It will spin and empty then turn off. we have seen the code UL what can be done to fix this?
UL=Ultra Level of water?
usually its just foam in sensor tube,as prior using too much or wrong type of detergent(for hand wash,or else). Do few cycles with just and only water,or open machine and blow tubes to level "sensor".
Jan 24, 2015 | Kenmore Washing Machines
I have a Kenmore Elite Total Care System Top Load washer, and for the past two days, the water level will not fill past the medium level even if the setting is on Large level.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Apr 17, 2011 | Washing Machines
Fills with water till it overflows especially in rinse cycle no matter what water level setting
most probably cause is water level/pressure switch or h hose.  either needs to be replaced or hose needs cleaning or came disconnected..
Jul 20, 2010 | Kenmore Elite 45986 Front Load Washer
No matter what the temp setting is at it only has very hot water
Your water temp is determined by 2 things. First the hook up to your water supply. If you are able to turn off the hot water valve that feeds the unit and then select a cold water only wash, do you get cold water?? If not then someone hooked up the hoses to 2 hot water feeds. If hot and cold feeds are installed right, the second thing is your computer which monitors the incoming temp through the boards atc control and a thermister. If you select cold, and only get a hum and the cold water valve is on, you may have to clean the screens in the valve of any sediment. If no hum, and no cold, dead solenoid on valve, but that would throw an error code usually. All fills are monitored by the board and usually begin with a hot/wrm mix and then changeover to a monitored cold temp , about 70 degrees.
May 05, 2010 | Kenmore Elite 45986 Front Load Washer
Water level won't fill past the lowest setting.
you may need to replace the level selector switch itself... if it has a reset option ( usually near the large side of the button, w/it plugged in, turn the switch all the way to reset, unplug the machine and then plug it back in. ) this has been known to work on occasion....hope this helps
Oct 18, 2009 | Kenmore Washing Machines
My Kenmore 70 is also overfilling...
Sounds like it could be a faulty water level switch. A defect or an obstruction can mean that it can't tell the water to shut off. This switch raises the water level in the clothes tub. It's usually a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, the pressure increases on the air in the plastic tube. When the pressure reaches a certain level, it activates the switch and turns off the water. It also signals the washer to begin the wash cycle. Clean out any obstruction in the plastic tube or replace the water level switch. Hope this helped.
Jul 16, 2009 | Kenmore 22422 Top Load Washer
Kenmore elite front loading wash & dryer-5 yrs old: should i buy?
all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Calypso kenmore elite water level low sometimes
something is clogging recirculating pump inspected both pump that should fix
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 80 series model# 110.28803890
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\www.sears.com.
Good luck.
barneyluc
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite HE3 washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 22422 Top Load Washer Logo
42 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
