Question about Mitsubishi HS-U446 VCR
My VCR inadvertently got 'locked'; how do I 'unlock' it?
  • clandersonsf Sep 02, 2010
    OK, so I'll get back to you in four hours...Conway
  • 11,896 Answers
Try unplugging it for about 4 hours. While unplugged, press and hold the power button for 10 full seconds half way through the time. Then after 4 hours, plug it back in and see if it resets itself.
Posted on Sep 02, 2010
How to unlock osd lock lg flatron w1643c
OSD LOCKED/UNLOCKED
This function allows you to lock the current control settings, so that they cannot be inadvertently changed. Press and hold the MENU button for several seconds. The message "OSD LOCKED" should appear. You can unlock the OSD controls at any time by pushing the MENU button for several seconds. The message "OSD UNLOCKED" should appear. system admin
May 30, 2012 | LG Computers & Internet
Sunroof will not work
Power is supplied to the Power windows and sunroof through the power window circuit breaker. That circuit breaker is supplied power through the RAP (retained accessory power) Relay, the RAP relay also supplies power to the radio. The RAP relay is also fuse protected by the RAP fuse in the under hood fuse block. The RAP relay is energized by the BCM body control module.
The RAP relay is responsible for the radio and windows working after the igntion is turned off.
The first place to check would be the RAP fuse in the under hood fuse block and then the RAP relay in the Body fuse block.
A list of the BODY relay block located on the left side of the dash to the right of the interior fuse block is below:
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay(1) Park Lamp Relay
(7) Door Lock Relay
(1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay (1) Park Lamp Relay (2) Courtesy Lamp Relay (3) Retained Accessory Power (RAP) Relay (4) Power Seats Circuit Breaker (5) Power Windows Circuit Breaker (6) Inadvertent Power Relay (7) Door Lock Relay (8) Headlamp Ground Relay (9) Driver Door Unlock Relay (10) Door Unlock Relay
Jul 10, 2010 | 2000 Chevrolet Blazer
Unlock philips dvp 721
my vcr dvd combo is locked could u please help me to unlock it
i can use VCR but dvd is locked
Nov 25, 2009 | Philips DVP721VR DVD Player/VCR
My Akai tvcd combination set is locked how do I unlock it.
try to press the display button on the remote for 5 secs. until the lock disappear then turn it off and unplug it.
Jul 30, 2009 | Televison & Video
Parental password control inadvertently activated.
Called Zenith. They said: turn on the DVD player. Hit "set-up". Scroll down to the "lock" icon. Scroll over to "Rating". Scroll over to unlock. Enter 0000. Click on Ok. Enter 0000 again, click Ok again. Menu should read unlock. Voila!
Nov 11, 2008 | RCA Televison & Video
The camera function will not work
Hey Uttado,
Check to see if the stanby lever that surrounds the record switch on the back of the camera has inadvertently been put on standby. If this has happened, the VCR will work but not the camera. Move it off of lock to standby and it should crank right up.
Apr 10, 2008 | Canon GL1 Mini DV Digital Camcorder
Proscan vcr plus gold stuck in lock
I just had the same problem and found a solution on the internet that worked. Hopefully you still have the VCR's remote control. Press and hold either the on/off, VCR1 or VCR2 button on the remote. I pressed the VCR1 button and held it for about 5-7 seconds. It released the lock and worked fine afterwards. The lock is some kind of childlock devise.
Mar 10, 2008 | Proscan PSVR73 VHS VCR
DVD/VCR Locked
My DVD/VCR Daewoo locked and everytime i pressed a button it just said LOCK! I plugged off the vcr for a few hours and then plugged it back in and pressed the on button. Now im watching the dvd that was stuck inside. Try it, you just never know.
Nov 19, 2007 | Daewoo DVRS04 DVD Recorder/VCR
Mitsubishi HS-U447 VCR in Lock or "Loc" mode
Hopefully you still the VCR. Your's is stuck in "CHILDLOCK" mode. To release the lock you have to have the remote and press the DISPLAY for 8 to 10 seconds.
The purpose of the CHILDLOCK is to prevent others from using your VCR. If you want to set the VCR back on Lock you again press the DISPLAY for 8 to 10 seconds.
This solution is from the owner manual for HS-U448, so I figure your model is the same.
Mar 06, 2007 | Mitsubishi HS-U447 VHS VCR
Samsung vr3607 vcr is locked
following is pasted from SV-7000W manual: 1 To lock the VCR, hold down the P/STILL (II) button for approximately five seconds. Result: The lock indicator (LOCK) is displayed. If a cassette is in the VCR when you lock it, the cassette will first be ejected. 2 To unlock the VCR, hold down the P/STILL (II) button again for approximately five seconds. Result: The lock indicator (LOCK) is no longer displayed. If that fails, try the same thing using the play/stop button. Cheers
Nov 13, 2005 | Samsung VR3607 VHS VCR
Mitsubishi HS-U446 VCR Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
