Rear speakers not playing - Audio Players & Recorders
  • lorez lolo Dec 31, 2008
    no rear sound i cant even adjust the power level
  • pope0825 Apr 28, 2009
    i just hooked up a rocketfish wireless speaker system worked great for a while then all the sudden it does not work now even when hard wired into the receiver ??? did it blow an amp or ic board ???
  • 979 Answers
Must have unit in some type of surround mode...accordianman
Posted on May 10, 2008
Overload
Probably dry joints around the power amplifier.
Mar 18, 2017 | Technics SA-AX720 Receiver
Lg HTS how do i change from stereo sound to Surround. The rear and centre speakers are not working at present
Music only plays through those two speakers, only movies with 5.1 format will play through all your speakers
Sep 18, 2012 | LG 5.1ch 1100w bluray hts 5 speakrperp...
Front speakers wont play but the rear dose
Swap the front speakers to the rear and the rears to the front. If the rears now don't play, it's in the radio. Double check the fader control. If that is correct it is the internal amp. If the fronts don't play after switching, it's the speakers. Use an Ohm meter to check the wiring and the speakers. It should be 4 or higher. If it is 2 or lower, it will cause the internal amp to fail. Check the wiring and make sure it is not pinched and make sure the speaker terminals are not touching metal where they are mounted.
Please rate if this was helpful!
Apr 10, 2011 | Car Audio & Video
Lg lht854....wont play sound out of rear and center speakers
Try setting it first on surround mode because it is normal for the rear speakers not to come on when it is the surround mode is off. For the center speakers make sure it is hooked up properly. Follow the instruction if you have one. Lastly I never heard of center speakers have two speakers in it but if it does and you only have one set of wire to it then one of the speakers is no good.
Jun 26, 2010 | LG LHT854 Theater System
I have an mp3 player that i want to hook up to my logitech x-540 speakers but when i do it only plays on the front, or rear speakers depending on which cord i plug it into, is there a way where i can use...
An MP3 player is a stereo device, meaning that it works on two channels - left and right. Therefore a 5.1 speaker system will only play on 2 speakers.
However, if you want to use rear speakers as well, just for the fun of it (you won't get any surround effects, both left speakers will play the left channel, and both right speakers the right channel) you can purchase a "headphone Y-adaptor", that normally allows two people to use two pairs of headphones on the same portable music device.
It has one headphone plug and two headphone sockets in parallel. Plug it into the player, and to the sockets plug the front and rear speaker cables :)
Please come back with a testimonial if helped :)
Dec 22, 2009 | Logitech X-540 Computer Speakers
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
Back rear speaker wont play when singled out. more details inside
I would suggest you mdisconnect the rear speakers from the amp, take a 9volt battery and click te speakers on at a time. If proble duplicated, the you have the left speaker tied to the right somewhere.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Only 3 speakers work!
I took the bottom off my go play to have a look inside, the internal port is connected to one rear speaker grill and the other is blanked off, so no sound will come out of that one.
Dec 24, 2008 | Harman Kardon Go + Play Portable Speaker...
5.1 Speaker Setup
check if the speakers are working with winamp or any other media player. If yes then install windows media player again. else there might be some problem with your rear speakers. check them out with a hardware service-person. if nothing works, reinstall windows. the default drivers will be loaded and your software problem is solved
Jan 29, 2008 | Audio Players & Recorders
142 people viewed this question
 Grubhead
Grubhead
