Question about Panasonic Lumix DMC-FZ7 Digital Camera
The lens will not open or close. - Panasonic Lumix DMC-FZ7 Digital Camera
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 02, 2010
How do I fix lens error problem on the described camera?
hi,
lens error occur normally when it fell or the lens shaken, if so open the camera, take the lens unit out, disassemble the lens unit, then fix it again properly. example below:
(this is not the told model)
Dec 10, 2015 | Nikon Coolpix S3000 Digital Camera
I have a hasselblad 503cx. when i hit the shutter button, the back part of the lens opens (where the film is) but the lens shutter is closed. when i let go, the lens opens and the back closes.
The proper order of exposure should be:
Curtain opens/Lense stops down (unless wide open)
Lense shutter closes
When releasing button, curtain closes
When winding, lense shutter opens
If this isn't what's happening, something is wrong. There is only a simple mechanical screw connection between body and lense, so it'd have to be an issue with the gears in the body.
May 21, 2011 | Hasselblad 503CX Medium Format Camera
The lens opens then closes then partially opens
Maybe some of the lens gear is broken . change the gear or lens will be ok .
Aug 31, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
The lens cover will not open and close all the way.
to open them completely simply push them with your finger. try doing so also when closing them. i have the same issue sometimes.
Jul 13, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
My son pulled out one of the shutters that opens and closes over the lens. The shutters no longer open all the way. The camera is brand new. How can I fix the rest of the shutters? Should I pull them...
You can pull off the other one if you want. To put it back in your basically going to have to take apart the camera. The "Shutters" on the outside is nothing more but to protect the lens will its in the camera. The actual shutter is inside the lens that open and closes very quickly when you take a picture.
Think of it this way, the shutter in the lens opens up to let in light that shows the image to the sensor behind the lens. Then it closes to "finish" capturing the light".
The "shutters" or "doors" on the outside do not move once you take a picture. They only close once the lens retract. (When the camera is turned off or idles)
Hope this has been helpful.
Mar 30, 2009 | Fuji J150w Digital Camera
Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 17, 2008 | Nikon COOLPIX L4 Digital Camera
Lens does not close anymore -
When you opened it the cog connected to the motor which opens and closes the lens probably shifted and no longer has traction against the ring around the inside of the lens which turns it to open and close it. If you open the camera up again be extremely careful - the lens has loads of springs inside it - lose one of these and it won't work properly. I opened up the whole thing to try and fix my lens which had been jammed in after a friend dropped it. I fixed the lens but couldn't put the damn thing back together again to many tiny parts and no guide to the jigsaw!!
Nov 16, 2008 | Casio EX-Z1050 Digital Camera
Coolpix lens opens retracts opens then closes again and lens error appears
Hello
When you turn the camera on the lens comes out and has parameters when extending to focus, if the lens does not open fully it sees a problem and then closes.
there are tiny plastic gears inside and may have chipped or a piece of sand got in causing the lens to jamb. "very fragile"
one solution is to ask a camera repair shop how much a lens mechanism would be to replace. (if cost is more than 1/2 of what you paid dont bother)
another solution is to have someone sell your camera on an auction site for parts, to make some money towards another camera purchase
Aug 26, 2008 | Nikon Coolpix L11 Digital Camera
Lens cover
I know this is an old post, but for those who want to fix it themselves: try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jan 16, 2007 | Casio Exilim EX-Z120 Digital Camera
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Aug 31, 2005 | Canon PowerShot S30 Digital Camera
Panasonic Lumix DMC-FZ7 Digital Camera Logo
55 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
