Question about Kenmore HE2 Plus Front Load Washer
Washer was running, Heard "clunck: sound. Washer turns on, but will not advance to any cycle. Just hear a "humming" sound
  • Kenmore Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description I suspect the belt may have come off or broke.
If you remove the back you should see something like this below...just an example and not necessarily your model...
Check to insure the pulley is tight as well.
Let me know what you find, good luck.
Macmarkus :)
Posted on Sep 02, 2010
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
We have a General Electric WJRR4170E1WW top loading washer that occasionally hums when it is running but the agitator doesn't turn. When it does this it will go all night in this mode and get stuck. We can...
sound like a stuck timer does it in all cycles!!!!!!!!!! permanet press cycle , regular cycle
if it does it in all cycles then definetly timer...
Jan 31, 2011 | Washing Machines
Air conditioner turns on in the inside but not the outside
The click you heard was an internal overload in the compressor. Your a/c shouldn't cycle on and off every few minutes. The short cycling causes the compressor to over heat. You need to figure out why you have such a short run time with your a/c. Check the thermostat.
Jun 16, 2009 | Goodman CKL24AR24 Air Conditioner
Frigidaire GLTF2940ES0 won't pump or spin
Sounds like a water valve solenoid. The hot and cold water is controlled by solenoids that open and close. Try running just the hot and just the cold. If one or the other works, then the proble,m is a bad solenoid valve
May 28, 2009 | Frigidaire GLTF2940ES Front Load Washer
Whirlpool Top Load Washer cycle problem
check the lid switch by putting a screwdriver into the lid switch hole; look at your timer duration diagram it's in the control panel a small sheet of paper taped inside Does you machine not advance mark the timer knob and, see how far the knob advances next set the timer for the agitate position and check the timer for continuity on those pins noted on the sheet
May 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch dishwasher timer freezing
There is a recall on the control board of many of these models, butyour problem is likely not related. It sounds like a plugged drain system or a possible bad drain pump. That's why you are hearing the pump running constantly. I have written a guide to help. It is here. Thanks!
Mar 24, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Bosch Next Pemium Washer-intermittent detergent dispensing cycle
Hi.
Sounds like the valve that lets the water in on the dispensing cycle is sticking, if you can hear the valve buzzing i would certainly suspect it to be faulty
Nov 23, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Kenmore HE2 Plus Front Load Washer Logo
135 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
