Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Timer doesn't turn on pump using the set point. It will turn off the pump with the set point.
I have the same problem with my timer. Did you ever solve your problem, and if you did...HOW?
Posted on Oct 11, 2010
Timer cuts on , but will not turn off
assuming that this is a mechanical timer with set points for off and on red points turn on and black points turn off. set the red point for your on time and then be sure to set black point for off. Best to tighten 1/8 turn (slightly) with pliers so it does not slip
Nov 11, 2013 | NSI Tork Timer Switches | Tork 1104-FM...
My woods digital timer is acting weird. I take the timer off the outlet and set the timer like normal. The display is doing everything I want it too at this point. But then, as soon as I plug it into...
Copy following link to identify timer and see Woods (Coleman) warranty support link
http://waterheatertimer.org/Woods-timers-and-manuals.html
Buy another timer.
Reset timer using reset button.
Check if timer has batteries. Older timers had batteries. Newer timers have internal rechargeable batteries.
Try on different outlet.
Check outlet polarity using circuit analyzer.
Timers are made to last 1-3 years, some more some less.
Jun 18, 2013 | Hardware & Accessories
Timer doesn`t work,doesn`t rotate.
If this is an electromechanical timer and the dial will not rotate, you can be pretty sure the timer motor is no good
May 21, 2013 | UPM 120V/240V Heavy Duty Outdoor...
As i saw the timer i wonder what is the use of that adjust around the timer..as i saw the model of the timer
Question doesn't make sense in english.
For foreign translation, you can use google translate.
http://translate.google.com/
Deihl analog timer has segments around edge of timer dial.
Segments can be set in or out.
Use finger to set segments one way or the other way.
The dial rotates a full circle each day.
The segments move small switch.
The switch turns light on and off.
http://waterheatertimer.org/images/Diehl-880-segments-A-.jpg
Open following link.
http://waterheatertimer.org/How-to-set-timers.html
Sep 04, 2011 | Diehl TIME CLOCK- 120V 24 HOUR
Sanyo television doesn't turn off either by using the remote or by turning it off at the tv.All other fuctions work using the remote or directly on the set.Even using the sleep timer doesn't turn...
Unplug the set and hold the power button for 30 seconds. Plug it back in and see if that fixes it. If it doesn't then it sounds like there is a problem on the board underneath the power button. Something isn't allowing the circuit to be cut.
May 05, 2011 | Televison & Video
I have GE Model #15089 digital timer. I want to reset time to come on to 7:30 pm and turn off at 10:30 pm. It was previously coming on at 6:00 pm and off at 10:30 pm and working fine but when I tried...
The problem with answering questions where somebody cannot program a timer, or programming stopped working, is that expert doesn't know if timer is defective, or needs to be reset, or timer has conflicting programming, or if person has mis-read the instruction manual, or if wrong button sequence is being used, or if internal battery has gone bad, or if circuit has interference or loose wiring, or if light bulb burned out, and however expert guesses, the person asking question is unhappy because the timer still doesn't work and/or the manual still doesn't make sense.
I work with timers every day and suggest the following steps to get started:
Reset timer and try setting program again.
Write out steps in manual at point where timer doesn't seem to work.
Double-check that you are pushing correct buttons all the way down.
Make sure same days of operation are selected for ON and for OFF. For example if ON is set for all days, and OFF is set for Tuesday, then timer will not work as expected.
Reset timer and make sure there are no conflicting or overlapping programs, or timer will not work as expected.
Test outlet with cheap circuit analyzer from home center, try timer on different outlet, try timer on different Load, check that Load works when plugged into outlet without the timer.
Save some headaches listed above, and buy another 15089 at Home Depot and return defective one in new package.
http://waterheatertimer.org/GE-timers-and-manuals.html#15079
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 25, 2011 | Hardware & Accessories
Intermatic PF 1102 digital timer with freeze control; Timer will switch from off to on to auto, but when switching to "on' the pump will not turn on. There is a "click" that indicates to...
The freeze control is wired parallel with timer, so both controls can turn Load ON-OFF.
So Load turns ON when either the freeze-control or the timer turns ON.
When both are ON, then Load will be ON.
Freeze control can be ON and timer OFF and Load is ON
Freeze control can be OFF and timer ON and Load is ON.
Only when both Freeze control and timer are OFF, will Load be OFF.
If pump is not turning ON below 32 (or the protection set point), then freeze control thermostat is suspect.
But you need to check if pump turns ON when timer turns ON.
If pump operates with timer, then freeze control is main suspect, unless there is a loose wire.
Open box and check for loose and burned connections.
If pump does not operate with either timer or freeze control, then check for loose wires and also check your circuit breaker and check that pump is operable.
To find replacement freeze control, Google search: Intermatic freeze protection thermostat
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 03, 2011 | Intermatic 24 Hour Electronic Timer
I have a t101 timer that hasnt been used for 2 summers. It is used to run my pool pump. I installed a new receptacle outside for pump and now the pump continously runs without shutting on or off according...
TURN BREAKER OFF TO TIMER , LEFT UPPER CORNER OF TIMER IS A TAB, PRESS UP ON IT AND AT THE SAME TIME PULL OUT ON THE YELLOW DIAL NOW YOU HAVE ACCESS TO THE CONTACTS ,POINTS . IF YOU FLIP THE ON OFF SWITCH YOU SHOULD BE ABLE TO SEE THE CONTACTS OPEN AND CLOSE. IF NOT THE TIMER MAY BE BAD . SEE IF YOU CAN.. WAIT NO NO NO THATS A 101. 115V CHECK YOUR WIRING JOB THE BLACK WIRE SHOULD BE HOT WIRE ITS IS SWITCHED THREW THE TIMER
Jun 05, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
29 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
