Question about InFocus ScreenPlay 4805 Multimedia Projector
4805 infocus projector
Occasionally the projector starts up with a squealing noise. Suspect bearing in the colour wheel.Does anyone else ever had a problem with this?Am I barking up the wrong tree ? PS :It is not the fan.
thanks Peter.(Apprentice idiot)
  • simonh May 24, 2008
    I have exactly the same issue - just replaced the lamp (after it would not fire-up). Lamp now works fine but I get the same noise... looking for a solution
  • Anonymous Jun 07, 2008
    Just to let you know I had the same problem 3 times(bad colour wheel) after the third time of sending it to be repaired I called the ceo of infocus
    and the fourth time I sent it in it was repaired correctly and has worked fine
    for 6 months now.
  • 2,237 Answers
It is the colorwheel bearings going slowly due to excessive dust and heat. remove the lamp and push in the switch actuator on the lamp door frame. turn the projector on and see the colorwheel spin in the lamp housing window. does the noise happen when the wheel spins and stops when the wheel stops? let the switch actuator go. does the noise stop? it's the colorwheel (pn: 525-0146-00). you can get it through an infocus service center. try av solutions in ny. www.avsolutionsny.com
Posted on Dec 01, 2009
    Scholar:
  • 167 Answers
No it's not the fan but it is most likely the fan driver chip is failing and is pwm driver and when it can no longer supply sufficient current it will cause the field coils of the fan to make a squealing sound and almost assuredly the fan is not spinning fast enough to provide proper cooling.
Also if the color wheel bearings were so bad that they are "squealing" the color wheel would never be able to spin up to phase lock, which in turn would inhibit the projector's lamp from striking.
Posted on Nov 29, 2009
We have an Infocus Screenplay 4805 projector. Our colour wheel has broken and we don't seem to able to purchase a replacement part from anywhere. Any help much appreciated!
Same problem... The manufacturer actually does not sell this part. You must simply purchase one off of craigslist or a broken projector and fix it with the parts. Here is a website that shows you how. http://home.comcast.net/~jexkids/Ebay/colorwheel/How_to_replace_Color_Wheel.htm
Nov 07, 2010 | InFocus ScreenPlay 4805 Multimedia...
My Infocus 4805 is just showing the INFOCUS logo and not showing the picture from the TV. all connections are correct but no signal....help
Powering On
  • If your InFocus 4805 projector is having a hard time powering on or doesn't power on at all, it could be one of two things. Due to the extreme temperature of the lamp that causes the temperature of the projector to rise, every InFocus 4805 projector has a cooling system. Check your projector's cooling solution, as it may need to be replaced. Also check the projector's fan---if the fan doesn't spin, the unit will not turn on. If the problem is the fan, you'll have to get it replaced. You can do this at the same place you bought your projector.
  • The Lamp
  • If your InFocus 4805 Projector powers on but does not project any light, the lamp will need to be replaced. All projector lamps must be replaced at some point---how often usually depends on how much use the device gets. Simply order a replacement lamp, unscrew the old one and screw the new one in. The projector will then work like new.
  • Color Wheel
  • If your InFocus 4805 projector powers on and is displaying images but the colors on the images appear warped or are not in the proper places, your "color wheel" will need to be replaced. The color wheel is a small device that essentially acts like a prism. Light is projected through it and it displays the appropriate colors on screen the way they appear in the original video source. Order a replacement color wheel that fits your model and use your instruction manual as a guide as you swap the old one out and put the new one in.
  • Aug 08, 2010 | InFocus ScreenPlay 4805 Multimedia...
    Where can I buy infocus scrrenplay 4805 color
    find the closest infocus authorized service center to you from their website. ask for part number 525-0146-00
    Oct 10, 2009 | InFocus ScreenPlay 4805 Multimedia...
    Color wheel
    Bid on a used Infocus 4805 on Ebay...So far thet is the cheapest and best fix for a color wheel
    Jul 22, 2008 | InFocus ScreenPlay 4805 Multimedia...
    Colopr wheel
    Comscan Electronics Maroochydore.
    We are able to source these colour wheels from the suppliers as we are authorized service agents for Infocus.
    Nov 06, 2007 | InFocus ScreenPlay 4805 Multimedia...
    Horrible noise
    it is the color wheel i have a similar problem and am looking for the part, the color wheel is a small electric motor that spins at a high speed and it can go bad. which will lead to the horrible squeel/hum/buzz.
    Apr 24, 2007 | InFocus ScreenPlay 4805 Multimedia...
    InFocus ScreenPlay 4805 Multimedia Projector Logo
    254 people viewed this question
    Top InFocus Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
