Question about Canon LIDE20 Flatbed Scanner
Blue tooth??? I downloaded the lide20 driver -it downloaded but then the attempt to attach it to bluetooth device failed????? Thanks Toni
  • 2 more comments
  • tonilind May 10, 2008
    That is the message I am getting from the computer-I have never used the blue tooth device. Thanks, Toni
  • tonilind May 12, 2008
    Mac OXS I download the lide 20 and the computer tries to send it to bluetooth-it never connects. I have the scan toolbox downloaded and it is ready to go but when I click the scan button it states there is no driver. Would you assist me:)
  • old marine
    old marine May 11, 2010
    That error message makes no sense at all. What version of Mac OS are you using? Have you checked on Apple's web site for that specific error message?
  • old marine
    Were you trying to attach the Lide20 to a bluetooth device? Or is that the message that you're getting from your computer? The Lide20 is not a bluetooth compatible scanner, so I don't really understand what the problem is.
    Scholar:
  • 111 Answers
The scanner is not a bluetooth device. In fact, the scanner is powered through the USB cable, so it must be connected to the computer.
Posted on May 12, 2008
My nokia n70 bluetooth is telling me unable to perfome bluetooth operation what is solution
Hi, Most Nokia phone all have similar problem about blue tooth operation failing.
What prompt "Operation failed" is when there an application on your phone , and an application your transferred through blue tooth or any other means has contacted Virus and it's affecting the blue tooth operation.
Solutions to this problem is to restore the blue tooth device back to normal by flashing the phone.
Flashing of phone restore back the lost or corrupted data on phones.To flash a phone, you will need to purchase a device used for flashing of phones. But to save you the cost of purchasing a flashing machine, i would advice you go to the nearest phone repair store around you for assistance. Skill personnel.
Thanks for using fixya..................
Jan 06, 2011 | Nokia N70 Cellular Phone
I wanne play my music via bleutooth but i dont find how i need to do dhat
Bluetooth technology makes possible sound transmittion to devices without the wired connections from the device out puting the sound out put gagdget. The bluetooth technology would only perform with devices that have that functionality. For example, once the device acquired on retail has indication of being developed to handle blue tooth technology also known as wireless connectivity, simply use the device settings to enable bluetooth functions. keep in mind that, blue tooth technology workswith only blue tooth gadgets. for example, a blue tooth phone requires a bluetooth ear piecees before functionanlity can be assumed with the settings. Once decided that each devices wanting to perform a blue tooth connectivity are designed for that function, use the settings function either on the menu area to set the wireless connectivity like also known. Remember, wireless cannot access another device that does not provide signals. in other words, once each devices setting are enabled, a signal should appear maybe blue light indicating blue tooth signal has been detected.The functions of thead set requires attempting to listen to any sound during the set up process. The entire process of setting bluetoothh should not be tasking.
checks to perform 1. make sure each device is designed to handle wireless signal recognistion also known as blue tooth technology 2. the devices may need to be set to allow access from the particular devices, a function that was design so that not all signals could be received by your heard piece. In the sitaution of which absence could be noice generation interfering the receiver and possibly preventign setthings
Dec 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
I go to the bluetooth menu and turn it on. it says "Bluetooth turned on" But the icon fails to appear and file transfer fails.
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 16, 2010 | Sony Ericsson K550i Cellular Phone
Driver for bluetooth dongle Device :- Blue tooth Dongle Problem:- Driver for Win Xp
http://www.bonphi.com/download.html
http://www.brothersoft.com/downloads/bluetooth-dongle-driver.html
http://download.cnet.com/Bluetooth-USB-Dongle/3000-18493_4-75778.html
Jul 11, 2010 | Computers & Internet
Bluetooth not working in sony W580i phone
After attempting on this process, if doesn't work,that means thee blue tooth is corrupted and to restore bluetooth, you will to flash the phone. Flashing the phone will restore back blue tooth.
You can use this links to see how to flash your phone.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Take care.
Jul 03, 2010 | Sony Ericsson w580i Cellular Phone
Bluetooth is not found in the control panel of my laptop
goto start and type bluetooth in search...if bluetooth drivers are installed ull get some icons like bluetooth, bluetooth devices etc.....try clickin bluetooth devices.....n u can try to connect with ur mobile.....if it doesnt show anythin u may have to install bluetooth drivers....hope this helps...
Mar 07, 2010 | Lenovo ThinkPad R61i 14 inch widescreen...
Problems with Bluetooth
Just download the drivers of blue tooth on your notebook correctly man.
then spam me if it wont work cuz i tell you what the next solutions ok.
Oct 20, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
The blue tooth function is not working on
I don't think your printer is equiped with a bluetooth device. You might try buying a standard usb bluetooth dongle and put it in the usb port on your printer. That might activate the bluetooth menu. That worked on my HP 6310AiO.
Sep 13, 2009 | HP PSC 2510 All-In-One InkJet Printer
Dell xps 730 19 in 1 memory card reader and bluetooth not working
Kindly un-install both the drivers for blue-tooth and wireless card from your computer. Just right click on each driver in the device manager select remove or un-install. Restart your computer and re-download the drivers from the dell support site.
www.support.dell.com
Note: dell support site would only contain drivers , for your xps system h/w that came from dell. if you have attached the wireless and blue-tooth later , you might need to download them from manufacturer website
Thanks
proton
Feb 15, 2009 | Dell XPS 730 Desktop Computer
Conecting Blue tooth phone to acer laptop
has your model actually got bluetooth built in as most Acer laptops have the switch, but do not have it fitted, if you do check in control panel> device manager and see if it reports any problems by way of an exclamation mark. You will probably have to purchase a bluetooth usb dongle for about £9.00 or $18 US and use that
Sep 14, 2007 | Computers & Internet
Canon LIDE20 Flatbed Scanner Logo
190 people viewed this question
old marine
old marine
