Question about Clarion Car Audio & Video
I need audio wiring diagram for 1997-2001 Infinity Q45 or which colors on each wire controls what the bose system in my 1993 j30 is shot this is the upgrade for that one but the wiring coloring is different as well as the harness pins plug into the back differently
SOURCE: wiring-audio system-1989 ford crown victoria
Tell Haynes not to cheap out and try to fit a decade of cars inton one book...I cant find the fuse block legend anywhere...what a rip
Posted on Oct 11, 2008
  • 6 Answers
SOURCE: need a wiring diagram for my 92 volvo 940 gl
Go to the following site and enter the make and model of your vehicle and it will give you a free diogram of the wiring to your stereo. The colors do not have to match up.
Posted on Apr 14, 2009
  • 883 Answers
SOURCE: wiring color codes for ford 2002 f250 radio
I can email full diagram to your email address...just post it here. I can tell you that power wires are:
1.) memory power (all times) is light grn / violet
2.) power in start position is red / black
3.)power w/ acc. delay is pink
4.) ground is black / light green
Posted on Nov 18, 2007
  • 152 Answers
SOURCE: 2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Good luck
Aduz
Posted on Mar 22, 2009
etirbynnor
  • 655 Answers
SOURCE: Need wiring harness color coded diagram for pioneer dehp6800mp.
Hello randscates,
Here's a link to the manual. The wiring color code for the supplied harness is on page 78. The diagram is rotated 90 degrees clockwise. I recommend that you download the PDF and print out the page you need.
Hope this helps.
Posted on May 16, 2009
What are the colors of the wirers to the fuel pump on 1994 infinity q45
Hope this helps. At the fuel pump, it looks like orange wire with blue tracer and a white wire. I looked at info for the v8.
Jun 20, 2017 | Cars & Trucks
2007 Nissan Altima Stereo Wiring Diagram for Bose Navigation
None are actually color coded. The schematic has the wire colors on it next to the wire.
May 01, 2014 | 2007 Nissan Altima 3.5 Sedan
Wiring diagram for 1997 infinity q45
hi i install a bose 7in cd player came with all the plugeto install it. but the factory radio comes with a amp en the amp do not tune on so audio for the speakers ;no sound comes out.i need the coloer of the wire.that will fix my problem.thank you .my email is. enriqueruiz98@hotmail.com
Jul 01, 2012 | Volkswagen Jetta Cars & Trucks
LOOKING FOR WIRING DIAGRAM FOR 1992 INFINITI Q45 FUEL PUMP NOT GETTING POWER OR RELAY OR SOMTHING NEED WIRING DIAG.
CHECK FUEL PUMP FUSE.AND SCAN CAR FOR PCM FAULT CODES.PCM CONTROLS THE FUEL PUMP.A HAYNES REPAIR MANUAL HAS FUEL PUMP DIAGRAM.
May 06, 2010 | 1997 Infiniti.5 Q45
Want to remove my Bose stereo system out of my 1998 Infinity Q45
Bose StereoCD and Cassatte for a 1998 Infinity Q-45
Sep 22, 2009 | Cars & Trucks
Bose amlifier
Power wire is usually yellow or red. A cheap test light from the parts store will tell you. The remote wire is almost alway solid blue. A volt meter will tell you for sure. Remember,the remote wire is very low voltage.
May 18, 2009 | Infinity 475A Car Audio Amplifier
My rear driver side window stopped working!
Sounds like it could be a short in your wiring. Or else it could be a fuse. Start there, check your fuses~~~
Mar 11, 2009 | 1997 Infiniti.5 J30
I have a 1993 J30 infinity need to disable security
OK well there might bee a key hole either in one of the door frames or in the glove box in witch you can use your key to deactivate the alarm and all the rest
the key hole will be covered up by a rubber or plastic cap so it is not visible
Dec 27, 2008 | 1997 Infiniti.5 J30
Audio wiring diagram
I have an 1993 Acura Legend L care with a Bose sound system. I need to find a way to remove the stereo for the serial number... any suggestions?
Sep 23, 2008 | 1993 Acura Legend
Car Audio & Video Logo
273 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
