Washing machine just bought machine digital trying to wash but monitor show door open although door is closed
  • Anonymous Sep 10, 2008
    door open? idicates on panel and is not open. Tried replacing the switch on door and did not help.
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 11, 2008
I cant get the door to close and lock? I just moved it. Is there a trick to this?
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, Rory shows us how to fix the interlock and door release mechanism on a Ho... ... How to Open a Washing Machine Door that's Stuck Closed - Duration: 1:30. eSpares 332,545 views ... Get video URL at current time. Getembed ...
How does a washing machine door interlock work? - White ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jan 16, 2016 | Washing Machines
My front loader washing machine won't open-the lock symbol disappears but despite putting the machine through a variety of cycles I can't unlock it
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ... to our channels social media as this really helpsmy site and keeps us going. ..... Front Load Washer Door Latch Troubleshooting Replacement ...
How to Open a Washing Machine Door that's Stuck Closed ...
? 1:30
https://www.youtube.com/watch?v=s-_x2tSmd0A
For all your washing machine spare parts go to http://bit.ly/1828iPF If your washing ... of thumps on the frontpanel next to the lock to see if this shocks it to release. ....impossible for ariston av51 washer, my arm cant go thru it...small space for ... How to open a washing machine door that won't open normally.
How to open a washing machine door that is stuck shut.
www.how-to-repair.com > ... > Door Locks & Switches
Jan 04, 2016 | Beko Washing Machines
My hotpoint aqualtis model number aq9f 492 u is showing f6 what does this mean
F06 Door lock fault
Issue: Washing machine door cannot be opened or closed / when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
Dec 29, 2015 | Hotpoint Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Hi I put some laundry in the washing machine (j845) and the door won't lock. It keeps saying error de although the door is very much closed.
de stands for door error.  electronics not sensing door open or shut.  could be bad control pcb or bad door switch ( solenoid ) or wiring harness...
Jul 08, 2010 | Washing Machines
Od litght is on but door is closed
OD Opened Door not sensed by machine control board Machine control board did not see the door open prior to the beginning of a new wash load. 1.Open and close door, then restart washer. 2.Check wire connections in harness leading from machine control board to door lock mechanism.
3.Check door monitor switch for welded contacts.
4.Check inputs and outputs at machine control board.
May 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
