Question about GE WBSR3140DW Top Load Washer
Washer fills and cycle starts water keeps filling at a much slower pace does this thru out all cycle even when reaches off still dribbles water into tub
  • GE Master
  • 8,220 Answers
You have a bad water valve. It might be the inlet screens or the innards of the valve have gone badwasher fills and cycle starts - fa7d938.jpg
Training manual for ge washers
Posted on Sep 02, 2010
    President:
  • 3,773 Answers
The water mixer valve need to be replaced.
Thats the thingy with solenoids that the hoses from the wall faucets
are attached to.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Water wont stop filling up
If water keeps filling or dribbling into the machine with the power off it's the water inlet solenoid. If it overfills only during the cycle then it is the pressure switch or pressure switch tube.
Jul 10, 2013 | Meiko Dishwashers
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
My washer will not fill with water or do any functions when i turn the dial
My Hoover 7700l ...on "fill" cycle, the water dribbles in. Takes hours to fill so we use buckets to reach the required level.
Tried: Swapping cold and hot water inlet hoses, making sure that dial is in "hot". This solved the problem for filling, BUT when "rinse cycle appoars, it's back to the dribble again.
any ideas?
Jan 23, 2011 | Maytag LSE7806A Top Load Stacked...
2 problems 1st is the washer continues to fill with water when i put in a new load second is it wont spin
If the water keeps filling without cutting off, you either have a faulty inlet solenoide or your pressure hose and or pressure switch needs checking.
To isolate the acutal problem, start the machine on a new cycle. Change the water level to minimum or low before you start. Let the machine fill up. Keep checking the water intake as it fill up. Once the water level goes over the half way mark in your tank, if the machine starts its wash action then your pressure hose and switch are o.k. as they have signalled to the timer that the water level selected, has been reached.
However if the machine keeps filling up even though the wash action has started, then you have a faulty inlet solenoide/valve. Turn off water at the tap and get the valve replaced.
Ash
Oct 26, 2009 | General Electric WCSR2090G Top Load Washer
When it gets to the rinse cycle, water is coming out of the hose into the sink not allowing it to fill, but their is a continuous dribble of water coming out of the hose into the washer, so whatever goes...
maybe your diverter valve at the pump is stuck open. Its a lilttle red box looking thing under the waasher by the pump. That little red box looking thing is you wax motor that has a plunger hooked up to a small looking piece. That wax motor moves the pluger in and out depending what cycle it is on. So im thinkng that went bad maybe and has the valve stuck open and thge water that is trying to fill is passing thru the pump and thru the drain hose. When the water fills its supposed to be closed tha way it contains all the water when it fills and wont let any get thru pass the pump and thru the drain hose.
Aug 05, 2009 | Fisher and Paykel GWL11 Top Load Washer
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
Amana washer only works on delicate cycle
Open the control panel. Unplug the timer and then plug it back in good and firm.
If it does not work correctly after that,
Replace your timer.
Mar 12, 2009 | Amana Washing Machines
Washer stalls while filling, must press start button to get it going again
How is the water tempture is it hot water when you have it set on hot?? and vice versa?? you may have a clogged fill valve screen you will need to shut off the water and remove the fill hoses and check the screens that are in the water inlet valve use a opened paperclip to hook and puul them out to cleans Hope this helps If not plz let me know and we can go futher into the mach
Jan 24, 2008 | GE Profile Prodigy WPSE4200A
GE WBSR3140DW Top Load Washer Logo
67 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
