Question about Philips 60PW9363 60" Rear Projection Television
Picture but no sound.
I have no picture but I do have sound. The screen is completly black and the menu will not come up. I was told to check the bulb but I cannot find one. It is a rear projection CRT television. Some please help.
  • Anonymous Oct 17, 2008
    I have the same problem, did you find a solution yet?
  • Philips Master
  • 3,459 Answers
You can get a repair kit from www.TvRepairKits.com for the audio but no video problem.
Posted on Mar 15, 2009
  • 8,596 Answers
The reason that you cannot find a bulb is that this model does not have one - it is a CRT projection, so it has 3 CRT tubes and no lamp. Sorry that you were given bad information - you would have been looking all day for that lamp.
Posted on May 28, 2008
    Novelist:
  • 142 Answers
I'm not sure of your particular model, but in general: in the rear of the unit is usually an access panel which you can remove. The bulb should be centrally located and is usually found within some kind of enclosure as it is EXTREAMLY bright and will blind you if you look at it directly. It is also located near a fan which is to keep it cool under operation. The bulb is approx the size of a small fist.
I know this is really obscure, but i hope it helps.
Posted on May 10, 2008
I have audio, but no video, what's up? last night I was watching, and the picture went out, I truned off the TV, then restarted it...the picture came back. Today I tryed to turn it on and no picture, just...
s the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
Oct 17, 2008 | Televison & Video
There is no picture on screen i can turn the power on and off thats all i can do i cant change the channel go to menu or anything else
Is the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
Oct 15, 2008 | Televison & Video
No Picture or sound on my JVC HD-56FN97 Television
No, if bulb is bad you will not see anything on screen.
Are outside sources connected to different inputs on TV?
Apr 13, 2014 | Televison & Video
Tv screen picture
it sound like you have a bad dmd bord that is whear the pix come from do it do all the time in video1&2 or hdmi
if so it could be antboard or the dig board to you should take to a repear shop.
Dec 07, 2009 | Toshiba 52HM95 52" HDTV Projection...
No picture
Seems like the bulb needs replacing.....
May 28, 2009 | InFocus ScreenPlay 61" Rear Projection...
46 inch rear projection tv bulb replacement model number 46gw944
1) In customer menu, adjust all video controls to center,then
increase "picture" to 3/4
2)Locate focus/screen adjust block above chassis...adjust
RGB screen controls for best mixture = B/W tracking..
Check with customer color level at minimum..should look gray.
If you turn screen controls up too much,you will see faint
re-trace lines in picture.....once B/W looks good,put color level
back to middle...................................................T.
Feb 05, 2008 | Televison & Video
No picture, just red-blue-green lines through the middle of the screen very faint.
The PT-53WX54 is a standard projection set and does not have a bulb. It has 3 separate picture tubes. If you have lost the picture completely, not even on-screen menu, then something has stopped working in your set. It could be a video processor, vertical deflection or possibly a convergence problem. The set should be serviced by a qualified tech familiar with the Panasonic projection sets.
Aug 22, 2007 | Panasonic PT-53WX54 53" Rear Projection...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Open Questions:
Philips 60PW9363 60" Rear Projection Television Logo
69 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
