Question about Dryers
My Kenmore 800 series dryer won't start when i push the start button. It does start to spin but stops after i release the start button. Any ideas what the problem might be??
  • Dryers Master
  • 8,220 Answers
This dryer has a broken belt switch. If the drum turns then the belt is not broken but the broken belt switch could be. The start switch itself could be the problem. This video shows how to get into your machine:
Posted on Sep 02, 2010
  • Dan Webster
    Dan Webster Sep 02, 2010
    If the belt is ok I suspect it would be easier to replace the start switch first. It is so easy to do . remove the knob by pulling it straight off. Then lift the locking tab and give the switch a slight twist. It comes right out. Their aare 4 wires 2 small ones and 2 large ones. You can't mix em up or connect em wrong.
2 Suggested Answers
ned_san_jose
  • 234 Answers
SOURCE: Kenmore 600 series dryer, has
Hello, I just repaired the exact same problem a few days ago. The problem is either your even heat board or the motor relay. There are two pink wires with black tracer on the motor relay on the right side. You should be getting a reading of 48 VDC when the push-to- start button is pushed. If you don't get 48 VDC, then you need to change out the even heat board. Hope this helps! Chances are, it's just the motor relay and should cost you under $20 to fix. If you have a technician look at it, then he should charge you under $100. Thank you.
Posted on Sep 23, 2010
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
The button the drum stops.When I push the start button the drum starts turning but when I release
it's the start switch on the motor . it might be bad or the spinning weights on the motor shaft may be gummed up with lint
you would have to take out the motor and check out the spinning shaft weights to make sure there clean and move to disconnect the switch when the motor starts.
my guess when you get in there you will find lint ,string and all such stuff all wound up around the shaft keeping the switch from working
Feb 02, 2016 | Kenmore Series 70 80 90 PN281798 Dryer...
Kenmore dryer won't start
Spin the drum by hand to see if you feel resistance. The belt may have broke.
Oct 21, 2012 | Kenmore Dryers
Kenmore 90 series... you push the start button and it hums but stops when you release the button and there is no movement with the tub
The infinity start button detent has broken.
Replacing the switch will get you up and running again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 01, 2010 | Kenmore Dryers
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
Dryer wont keep spinning without me holding the start button down
Weird timer problems are a pretty common occurance try this link! hope it helps ps don't forget to give me a ranking THANK YOU!!
http://fixitnow.com/wp/2008/09/27/weird-timer-problems-in-a-whirlpool-kenmore-dryer-with-electronic-control/
May 06, 2009 | Kenmore 64902 Electric Dryer
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Dryers Logo
355 people viewed this question
Top Dryers Experts
