Question about Reliance & 40 Gal Electric Mobile Home Water Heater
Keeps triping red reset button 640 dors - Reliance & 40 Gal Electric Mobile Home Water Heater
  • 349 Answers
More than likely it needs to be replaced if you have to constantly reset it. Shut of power and repalce thermostat, it just snaps in place and easy to remove.
Posted on Sep 02, 2010
Reset button on a o smith keeps tripping
After the high limit trips once, it is no longer calibrated. Replace the upper stat and limit.
Mar 21, 2017 | Water Heaters
Water temp to hot,,turned all way down,changed thermistates still the same,and pops the reset button
short in the wiring bypassing the thermostats
get an electrician in as the fault is serious enough to need it resetting
May 07, 2016 | Reliance 606 Series 40 Gallon Electric...
Thero. knocks off
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Replace both thermostats. One or the other is sticking, and there is no way to test which one is bad... since test unsticks a stuck thermostat
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 01, 2014 | Reliance 606 Series 40 Gallon Electric...
I have a Reliance 501 model # 5 30 2srs4. I had to reset the unit after waking up to cold water. The water heated up in no time at all but the water was super hot. So hot it triped the reset button again....
No, the top thermostat will always heat first and then it should dwitch the power to the bottom one after the top of the tank heats...this is to get you hot water faster...
The top thermostat is bad and is not shutting off or switching....
Replace the top thermostat/reset combination and you''l be good!!
Check out this tip..
How to replace the Thermostat and Element for
Electric Hot Water Heater
heatman101
Jan 03, 2011 | Reliance & Lowboy& Electric Water Heater
The therostat breaker keeps triping no mater what the therostat setting is. I have to reset the breaker each time i want hot water. Is this GE solution to save energy?
It sounds like the thremostat may be shorting out they are not to exspensive to replace.
It it constantly triping there is a wire touching somewhere.
May 16, 2010 | General Electric GE SmartWater Household...
Reset button triping on bradford white electric water heater
replace upper thermostat, and hi temp limit, usually made in one piece, also make sure the new stat is pushed up tight to the tank when you install it.
Dec 05, 2009 | RTO Bradford White M-1-20U6SS 19 Gallon...
Resetting 81vp6s
I can not find any info about your model from there website.
Normally you remove the cover that is on the side of the unit, remove
the piece of insulation and you should see a black box,which is the thermostat control , on it there is a red button, this is the reset.
If this keeps tripping,but never did before,it could be the heater element is going bad and more so if you have hard water.
Apr 15, 2009 | Rheem 81VP6S/430126 Water Heater
Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Jan 21, 2009 | Water Heaters
Reset keeps triping
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/250SXTechSupport/Troubleshoot/tabid/563/Default.aspx
click on this link and it has the troubleshooting in strucktions for the unit . hopt that it helps you out.
Jan 11, 2009 | Bosch Water Heaters
Reliance & 40 Gal Electric Mobile Home Water Heater  Logo
158 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
Paul Nielson
Paul Nielson
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
