Question about Sloan M-101526-F42 Flushmate?® Complete Replacement System for FM IV 504
It dosent hold the pressure all the time - Sloan M-101526-F42 Flushmate?® Complete Replacement System for FM IV 504
  • 22 Answers
If you haven't already, I suggest contacting Flushmate technical support at the toll-free number on the serial number label. They'll need the serial number off teh Flushmate and will be able to guide you in identifying the source of any air-loss and recommending a solution.
If it's under warranty and replacement parts are needed, they'll send them at no charge.
Hope this helps
Posted on Sep 02, 2010
Add coolant
Need to run PSI check on Cooling system should hold steady at 15psi for about 15 min. Check for leaks while waiting. if you see none and you lose pressure could be a bad intake gasket.
Feb 28, 2014 | Ford Explorer Cars & Trucks
Power steering pump dosent last
Sounds like impurity in the oil.
Strip the rack and clean out. or replace both units ( pump and rack)
As all the junk usually ends up in the rack ready to destroy another pump
Oct 22, 2013 | 2006 Pontiac Grand Prix
I have digital blood pressure monitor Model bp3bm1-3.it is not turn on, why ?
i have micro life bp aparatus since 3 years but from last month it diosent work good every attampt it indicates low blood presure at all on screen it dosent go up by 140 and all the time it shows 90 / 50
please advise what to do
Sep 27, 2012 | Microlife 3AC1-PC Blood Pressure Monitor
Why dosent my car advance when i step on the gas pedal
From what you say Daniel, your kickdown cable need's to be adjusted, here's how :
Down at the pressure lever on the front of the trans, loosen off the cable retaining nuts so there is a little slack in the cable.
then start taking the slack out of the cable a little bit at a time;
Rest a long screwdriver on the end of the pressure lever, holding the screwdriver with one hand start opening the throttle with your other hand.
Just at the point the idle RPM barely rises, the pressure lever should just barely move.
Driving test; Going along a level road at 25 mph light throttle, floor the gas pedal.
The trans should downshift to first gear.
repeat the same drive at 28 mph, floor the gas pedal, the trans only downshifts to second gear.
Sep 10, 2012 | 1990 Honda Accord
I have 04 titan, i step on gas but at 4000 rpm start feeling like something is holding it , it dosent go any futher !!!
cat is probably plugged. rev it up and check the pressure coming out of the exhaust pipe. if its weak then replace the cat with a test pipe to make certain.
Jul 22, 2012 | 2005 Nissan Titan
1999 chrysler sebring oil pressure drops when the car warms up but wheh you mash the gas, the pressure rises.the car use to shut off when the oil pressure droped but now it dosent. i replaced the oil...
I think your sensor may be affective. The same thing happens to my sebring and it has been like that forever. You can check the oil pressure sensor and see if it needs replaced.
Feb 05, 2011 | 1999 Chrysler Sebring
Overheating 2001 chevy impala
Believe it or not, new thermostats can be bad. Did you maybe get some adhesive on the thermostat preventing it to open fully? Is the thermostat installed with the crown up? The only other thing that I can think of, if it's a closed cooling system and the wrong radiator cap is installed, it won't hold the pressure, therefor overheating. The other thing may be the water pump. Many times the impellers will wear down internally causing to low of water flow.
Jul 16, 2017 | 2001 Chevrolet Impala
My mp3 dosent work!!!!!!!!!!!!!
mine did this too when it was new, just hold down the menu/power button for 15 seconds, depending on how fast your counting you might have to hold it down longer.. that will reboot it (sometimes it delets the tracks, just warning you) and other times it just restarts it.
Nov 30, 2008 | SanDisk Sansa e250 MP3 Player
Sloan M-101526-F42 Flushmate?® Complete Replacement System for FM IV 504 Logo
150 people viewed this question
Top Sloan Home Experts
richochet
Andrew Taylor
Andrew Taylor
frankdanfelt
Are you a Sloan Home Expert? Answer questions, earn points and help others
