Question about HP Compaq Presario V2000 Notebook
Lcd latch switch
How can i replace or repair LCD latch switch
  • 1,601 Answers
Here is the manual for your laptop..You will find your answer here
Posted on Jun 09, 2008
  • 207 Answers
U cant do it send it send to repair station
Posted on May 19, 2008
How doireplacelcdscreenoncanonpowershots51s
I would not try myself. It is likely to require very delicate connections. If you don't care about using the camera, then go ahead. If you care, see what a repair job will cost.
Jul 14, 2014 | Canon PowerShot Cameras
LCD Screen
If it's a spring loaded type latch mechanism, It may be as simple as a spring. Carefully remove the bezel and take a look.
Jan 19, 2013 | Acer Computers & Internet
I have a Sony A300. When I turn on the live view screen, I only see a bunch of vertical lines on the screen and cannot see anything that I try to display (ie. menu, display, prior photo's, or the...
Sorry to say your LCD screen is cracked, it happens a lot with the Sony DSLR-A300 and A350. The solution is to remove the cracked LCD and replace it with a new one. The repair isn't that difficult, but you have to be careful removing the LCD or you will break a latch holds two FPC cables together and then will have to replace yet another part that takes MUCH more labor.
I did a Google search for "sony a300 lcd repair" and at #2 I saw an online digital camera repair shop that has done tons of this repair over the last few years.
Hope this helps!
Thomas Drayton
Owner, Digital Camera Repair
Jul 11, 2011 | Sony Alpha DSLR-A330 Digital Camera
Hi How do I take the cover off to replace the screen? Toshiba A105 S1712
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The LCD screen mask is secured by five screws. These screws are hidden under the screw seals.
Remove three screw seals from the top and two seals from the bottom of the LCD mask.
Remove LCD mask securing screws.
Start removing the LCD screen mask with your fingers. Place your fingers between the mask and the screen and release plastic latches.
To release plastic latches on the side you can use a guitar pick. Do not use a screwdriver or you can damage the screen.
After all latches are released, you can remove the LCD screen mask.
Nov 03, 2009 | Toshiba Satellite A105 Notebook
How do I replace lcd screen in kodak C653 camera
You may purchase LCD screen for your camera at
Try the steps below on replacing the LCD screen.
1.take all screws out.
2. unsnap the case carefully.
3. slide black clips on both sides of LCD leads, both have them.
4. slide new screen into place, slide black clips back up, latch down screen.
5. replace case then screws. Done Deal.
If camera worked before it will be better now.
But if your camera still In warranty, you may call Kodak at 1.800.235.6325.
Sep 22, 2009 | Kodak EasyShare C653 Digital Camera
Latch broken
To repair that will require the replacement of the LCD back plastic assembly, you can find them on Ebay
Jul 03, 2009 | Dell Computers & Internet
Replaced lcd get white screen
If you bought the new 'super bright' lcd for ipods then this is the problem. The new 'super bright' lcds for sale on ebay are only for 6th gen ipods. Buy a 5th gen lcd and all problems will be solved.
Mar 21, 2009 | Apple iPod MA446LL/A MP3 Player
Tosiba saterlite A100 pro- how do i dimantle
1. Release the following 10 latches on the switch cover, in that order:
- Six bottom latches (near LCD/ Hinge side)
- Four front latches
2. Remove the speaker cover.
Remove 2 screws holding keyboard in place lift up and
Remove the connector CN11 on main board and keyboard.
The odds of "Repairing" the keyboard are practically nill, I would use an external until a replacement could arrive. LINK
Jun 03, 2008 | Toshiba Satellite A105 Notebook
Ilo LCD screen Burn
Replace - not repairable
Feb 29, 2008 | iLO (2 GB) MP3 Player
EVO n610c screen goes off
Hard Rock,
This issue is caused by an over sensitive LCD cover switch. The way this switch works is as follows.There are small slots in the top cover that the LCD latches into when closed. The slot on the left side has a brass clip, which acts as a lever to active the cover closed switch on the system board. The LCD latch pushes down on this lever to turn off the LCD. On your unit this clip has been bent to the point where any pressure near that slot actives the cover closed switch. The fix is to remove the top cover of the laptop and carefully bend this clip. Then reassemble the laptop to test it. It may not work on the first attempt. Its tricky.
Dec 02, 2007 | Compaq Evo N610C Notebook
HP Compaq Presario V2000 Notebook Logo
73 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
