Question about Cameras
I can't take a picture my camera state "Card Locked"
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 02, 2010
L have a sensory pleasure nv3 camera but l am unable to take a picture due to card locked how do l cancel this problem
There is a small slider switch on the side of the card slide it to 'unlock' and try again
Feb 15, 2015 | Cameras
I turn on the camera and it states' memory card error'. I can't take a picture or view the pictures on the card.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Feb 20, 2011 | Canon PowerShot A710 IS Digital Camera
Camera is stating "card locked" and can't take a
Take the memory card out of your camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 20, 2011 | Vivitar ViviCam 5385 Digital Camera
Memory card locked
Move the slide switch on the side of the card.
Feb 28, 2010 | Sanyo Xacti S650 Digital Camera
SD630 camera states error memory card? New Card 2GB SD Card. Then it states card locked removed card and still says card locked. Will not let me go into format on tools. please answer.Do I need to just...
On the side of the SD card there is a little switch for locking the memory card to prevent erasure or writing. Make sure it is not locked. After that try a smaller size card. After that junk it.
Nov 18, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
The card is locked appears on screen when SD card is inserted
Is it possible for you to use some tweezers and adjust the very small lever inside the camera's card bay? It may be stuck thus telling the camera the card is locked.
Aug 27, 2009 | Casio Exilim Zoom EX-Z80 Digital Camera
Memory card error (states memory card locked) not locked
Remove the card and look for a tiny slide switch on the side of the card. Slide this switch to the other "unlocked" position. Reinsert the card and try it out.
Jan 11, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
Kingston 512 mb memory problem
Check your manual to see where the lock/unlock device is on the camera.-
Jul 14, 2008 | Samsung Digimax S500 Digital Camera
Locked memory card
remove your memory card from your camera. on the left side of the memory card has an unlock switch. Just raise the switch to unlock it.
Jul 13, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
