Question about Garmin GPSMAP 295 GPS Receiver
Garmin gps 296
Bought a gps296 about 3 months ago hardly used it !!! it wont power up now I was told it was the battery so got a new one still wont power up or evan show the battery on charge.
Any way to do a reset or something????
  • Anonymous Apr 25, 2009
    My 296 won't charge. The display says "charge complete" but the battery icon shows empty. The battery really is empty. The only thing I'm sure of is that the problem is not with the battery... I have two new ones that it won't charge. The problem is obviously in the unit. Anybody need some extra batteries? I have 3.
  • 454 Answers
If it does not show 'charging' when connected to power, then something may be wrong with the power cord. If it is the vehicle cord (the one with the cigarette lighter plug) check the fuse in the tip of the cord.
Posted on Aug 12, 2010
I used it 10 months ago. its been in the car ever since and when i tried to use it i get the garmin name and then it goes blank.
If this happens even when the unit is plugged into the power source (lighter) then you should replace the battery. You can search online for battery replacements and instructions. Then plug into your PC for garmin updates. Updates are important for Garmins.
Apr 09, 2014 | Garmin nuvi 2797LMT - GPS receiver
Trying to charge my Garmin 396 with external power. The unit is showing "Battery Missing". However my battery is there.
I had this problem on an aftermarket battery I purchased last year. It worked well for several months but recently gave me the battery missing warning and would not operate the unit at all. I checked the voltage on my Garmin OEM and on the new one. The Garmin OEM, showed 8.1V on two readings, between the center and right terminals and about that between the two outer terminals. The OEM showed around 5.7 so that implied that it had some bad cells and not a broken wire. I tossed it and bought a new aftermarket unit last week. That one doesn't show a full charge and when I switched back to the Garmin battery it shows 00:00 time remaining, but still 8.1V. Maybe I should have just bought a new Garmin battery!
Jan 28, 2011 | Garmin Replacement GARMIN GPSMAP 396 GPS...
We bought the Garmin Nuvi 1300 a few months ago. We were travelling X-country when it would just shut down for no reason. When you turn it on it will turn off almost immediately. I bought another one in...
It sounds like the battery is the issue. Try leaving it plugged in over night. If that does not help, press and hold down the power button for 30 seconds. This will reset the device, and hopefully restore functionality. Consult the user guide for more info.
Aug 23, 2010 | Garmin nuvi 1300 Car GPS Receiver
Hello, My Garmin 260 ran out of battery 3 months ago. I did not attempt to recharge it until two weeks ago. i used a usb cable and plugged it into my computer overnight. It still did not charge... what...
http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+260&Show=ExtInfo&gclid=CLzv0pac46ECFQQTawodklsxIg.
This place has the battery and tools come with it!. its super easy and way cheaper than buying a new garmin. 2 screws and unplug the old battery and plug in the new. I did mine and I never messed with the internals before.
May 03, 2010 | Garmin nuvi 260W GPS Receiver
Will not turn on
I have a garmin 255W when turning on all itdoes is go to a white screen with black dot thatsay Press dot .It wont turn on how do you fix this
Jan 19, 2010 | Garmin nuvi 255W GPS Receiver
Garmin nuvi 205w CAN'T UNLOCK MAPS don't have codes it is used...
You are out of luck. Garmin will only talk to and assist registered owners. The registered owner has to deregister the device before a new owner register it and update the maps.
Mar 17, 2017 | Garmin nuvi 350 GPS Receiver
Battery on Nuvi 750
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Jan 19, 2009 | Garmin nuvi 250W GPS Receiver
Powerless garmin
When leaving the unit not powered up for so long, the internal battery may be damaged. The power supply will not start up if the internal battery is defective.
Sometimes the internal power supply may become defective in this case and must be replaced along with the battery. Contact the manufacture for details about how to get the unit serviced.
Jerry G.
Jun 01, 2008 | Garmin StreetPilot C330 GPS Receiver
No power
I had exactly the same problem with a 3 month old Zumo 550. Removed battery, waited a few minutes and replaced. System now poers on OK. All data on-board was retained.
Dec 22, 2007 | Garmin zumo 550 GPS Receiver
GPSmap 60Csx power up problems
I had the problem where I ended up disassembling the Garmin and adding a small piece of plastic to the on/off button. For some reason the push button on the top does not reach the one on the circuit board.
Oct 19, 2007 | Garmin GPSMAP 60CS GPS Receiver
Garmin GPSMAP 295 GPS Receiver Logo
808 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
