Question about Philips 50PF7321D 50 in. Plasma HDTV
50PF7321D/37 won't turn on --Red led flashes 4 times--
  • 90 Answers
SOURCE: Red flashing light. Light flashes red 8 times pauses & repeats
power supply board going bad
Posted on Mar 03, 2009
  • 44 Answers
SOURCE: Philips 42'' Plasma TV 42PF7320A/37 red led error codes
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
SOURCE: tv red blink no start42 plasma philips
Thank you for the help. I actually changed the whole main power supply board and it still did not fix the problem. When I put the new one in, I had the tv on for about 3 hours and then I shut it off. No sooner did I get it back up on the wall and the problem started all over again.When I pulled the original board, the caps all looked fine so I am not even sure the board is bad. Problem is there is no one around me to test it. I am not going back to the same shop that already told me that it was a bad main power supply board. Any other suggestions?
  • 67 Answers
SOURCE: 42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Posted on Jul 25, 2009
roety
  • 585 Answers
SOURCE: my 42pf7421d/37 flashes a red light when i turn
Hi, philips (sony and others) uses the flashing red lights to give an error code, but all that means is that a circuit is probably shorted and doesn't always indicate specific components,.
42pf7421 is an LCD that basically has two large circuit boards in it. If you have technical ability you can examine the power supply to see if any capacitors are swollen on their top sections. this is a common failure in many LCDs and Plasmas, but would require soldering to replace them. If no caps look swollen troubleshooting this set would involve voltage checks , a service manual and board replacement.
Could be either the main board, power supply or possibly a bad screen (panel) If you have the set open you can sometimes see the LCD bulbs light for a split second indicating that a problem with either the panel itself or the ballast power section. If it lights for a second sometimes I can see that one bulb is not lighting. One bad bulb will cause the set to go into shutdown mode , indicating a bad screen (panel) .
I hope this info helps you decide on the options before you
1. call a tech expect to pay an estimate fee, parts and labor btwn $200-$1000
2.check the power supply, reseat the panel cable, look for a momentary light of the screen. order a suspected part and replace it yourself.
3. buy a new TV (sry bad option)
hope this helps
Eric
Posted on Sep 01, 2009
I have a Philips 42pf5321d/37 that won't turn on.
send me a email sonny@tvcircuitboards.com and I can assist you with troubleshooting it to determine whats happening with the set.
Aug 07, 2012 | Televison & Video
No picture on Philips Model # 50PF7321D/37
The LED normally blinks--indicates the digital/main board is powered up.
Look for other fuses----Boards for these are rather expensive, maybe too expensive.
Google the model number with the word boards or parts after it to research it.
Mar 14, 2012 | Philips Televison & Video
I have a 50pf7321d 50"
Oh. It's Great. Never show it to anybody!!!!!
Jun 29, 2017 | Philips 50PF7321D 50 in. Plasma HDTV
Philips 50PF7321D 37 - It won't turn on then RED LED blinks 4 times
look for bad capacitors on the power supply board and replace
Feb 27, 2011 | Televison & Video
Philips Power supply flashes 5 times
one day not start his open. stan by red led and after switch on ,his green bligkig is not open.sound is ok.(the relay his not click)
Apr 12, 2010 | Philips 50PF7321D 50 in. Plasma HDTV
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
42pf7321d/37
relay clicking is a power board failure --- part of the board still works to supply power to the flashing lights--- the lights are related to an error code while in protection mode
Oct 12, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 50PF7321D 50 in. Plasma HDTV Logo
228 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
