Question about Dell Microsoft Windows XP Home Edition
WIRELESS THE WIRELESS IS STATING THAT IT IS CONNECTED AND THE SIGNAL STRENGTH IS EXCELLENT BUT THE INTERNET WONT WORK WITHOUT THE ETHERNET WIRE CONNECTED INTO THE LAPTOP AND ROUTER. I HAVE RANG THE INTERNET PROVIDER WHO HAS GONE THROUGH ALL THE SETTINGS AND SAID THE SETTINGS ARE OK. SO THEY SENT OUT A NEW ROUTER THINKING THIS WAS THE PROBLEM. BUT ITS STILL NOT WORKING????
  • 6 Answers
So, what kind of wireless card or adapter on your computer/laptop?
Posted on May 10, 2008
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
My laptop keeps saying validating identity and it wont go on line troubleshooting says things seemed to be ok but its trying to say a cable is unplugged or my local area connection is firewalled and i
You didn't provide your router make, model, so this is a general procedure. Wired or Wireless connection? You didn't say? Shut down the computer, unplug , remove battery. Unplug the wired/wireless device,. Unplug the ISP modem, remove battery, if applicable. Verify ALL cables and connections. Replace battery in the ISP modem, plug in, wait for selftest. Plug in the wired/wireless device, wait for selftest, If wireless, try a Ethernet cable to verify your router is connecting to the ISP modem. I would suspect a Laptop issue.
Jan 04, 2013 | Computers & Internet
I have an acer extensa 5620z and netgear dg834v5 modem/router. I can connect via ethernet, but even though i have set the router without security, the laptop detects the wireless network, but won't...
This is worked for me on Vista:
1. Goto Network and Sharing Center.
2. Click on your Wireless Connection "View Status".
3. Click on Propertes.
4. Uncheck the option that says "Internet Protocol Version 6"
When I did this, my wireless began working again.
Jun 11, 2011 | Acer Extensa 5620 Notebook PC
Unable to connect Acer One D250 netbook to 2wire modem. Limited or no connectivity. I can connect through wireless at work and hardwire.Comments: Dec 30, 2009- Netbook sees the network, has excellent...
Replace the Cable and Check.
If the problem still persists then
Give the same network setting to the wireless network adapter as you assigned to your local area connection.
Note: Before doing that remove the IP address of that Local area connection or change it's IP address to some other number.
This will most probably solve your problem.
Otherwise, Used an external USB Wireless Adapter.
Jan 01, 2010 | Acer Aspire One PC Notebook
Can not connect wirelessly with router
The list of wireless routers that are available in Windows is very limited and the signal strength of any router that is detected is weak. This can occur when the Lite-On USB Wireless 802.11 b/g hardware and Windows are not able to fully synchronize the signal strength data. Figure 1: Example of detected wireless devices when the antenna cable wire is connected to secondary port c01153759.jpg Figure 2: Example of detected wireless devices in the same environment when the antenna cable wire is connected to primary port c01153760.jpg To correct this error , download and install Lite-On USB Wireless LAN Driver Update (sp35177) (in English) from the HP Web site. This update should only be applied if your PC has the Lit-On USB Wireless LAN adapter and is exhibiting the symptom. As a work-around, you can connect the wire that runs from the wireless antenna port to the primary port on the cord as follows: CAUTION: This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
  1. Open the side panel.
  2. Find the wireless networking board by following the antenna wire connected to the wireless networking antenna port on the back of the computer. Figure 3: Wireless networking hardware c01153761.jpg 1 - Wireless network board 2 - Antenna wire 3 - Wireless networking antenna port
  3. Very carefully, disconnect the small wire from the board by gently pulling the end of the wire away from the board.
  4. Connect the wire to the other available port on the board. Figure 4: Available port c01153762.jpg
  5. Replace the side panel, connect the power cord, turn on the computer, and use the computer again to verify that wireless signal strengths have improved.
Jan 14, 2009 | Acer Aspire 4520-5582 Notebook
Limited or no connectvity
you can use the WinSock XP Fix tool to reset TCP/IP protocol to original state: http://www.snapfiles.com/get/winsockxpfix.html
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Belkin Mimo Router
If you're connected to the router with excellent stregth then the problem most likly lies in the routers connection to the internet. Check your DSL, Cable modem and make sure the connection to the "Internet" port on your router is good. Try switching out the Ethernet cable if nessciary.
Feb 22, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
98 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
