Question about Vicks Warm Mist V745A 1 Gallon Humidifier
How do I clean this humidifier if it smells a bit like mold?
    Problem Solver:
  • 14 Answers
Mix in with the water a small amount of anti fungi solution specific for humidifiers. You can find these solutions at walmart or target.
Posted on Sep 02, 2010
2 Suggested Answers
  • 10865 Answers
SOURCE: how do i clean the mold off my humidifier?
Fill it to with in an inch of full, add two tablespoons of clorox and fill it the rest of the way. Run it for a few minutes and then just let it sit over night. The next day empty it out and refill it with fresh water and one teaspoon of clorox. You will be good to go.
Posted on Apr 02, 2009
Mold in the machine. how do I clean and disinfect it?
The best way to get rid of the mold is to use bleach water. You need to clean and scrub it out, making sure the bleach gets in every cranny. Lastly, really (and I mean really) rinse it out. I would suggest washing it out several times to be careful.
Elisa Jed ' http://www.colfaxcorp.net/services.html
Apr 06, 2014 | Venta Airwasher VS 207 3.7 Gallon...
Is mold ever a problem with this unit
As far as I'm concerned mold is always a potential problem with any humidifier. You can buy a cleaning solution at most hvac supply outlets that will keep this to a minimum and also smells good. If you want to do it for less money and don't mind the smell of chlorine then use 3-4 ounces monthly to control mold and bacteria growth. Thank you.
Feb 05, 2011 | General Filters 1099-LH Humidifier
Cleaning internal humidifier
Try using vinegar and distilled water.
If this does not work try using a little bleach and water. Repeat till mildew is gone.
Rinse thoroughly Again & Again.
Everyday humidifiers should be cleaned.
After your last uses try blow drying it. Before you put it away. If it's dry it will not mold or mildew.
Mold & mildew will cause you to get very sick.
If the mildew does not go away replace your unit.
May 19, 2010 | Humidifiers
Moldy smell
Replace humidifier media pad (filter) with a new one, and clean interior of humidifier housing with a solution of warm water and vinegar, also replace or clean furnace filter, Good luck.
Mar 02, 2010 | Humidifiers
Mold is developing in drainage tubing - how do I prevent?
Keeping the humidity level in your home below 50% will greatly decrease mold growth. You can pour some bleach in the drainage tubing to clean it out and do it every three months to keep it clean
http://www.ehow.com/how_4798220_clean-honeywell-humidifier.html
http://www.forwardthinking.honeywell.com/related_links/humidification/truesteam/sell/50_9718.pdf
Feb 28, 2010 | Honeywell HE260A1010 Whole House...
Steam not released through spout but trapped
is the spout clogged? Try running vinegar through it, CLR is a good product, but may stay the plastic, if not eat it, so I recommend vinegar to clean the deposits that plug things up, it may smell a bit, but usually works. Once cleaned, use distilled water to keep it from happening again, or just clean regularly with vinegar.
Feb 28, 2010 | Bionaire BU4000-UC Humidifier
How to clean a moldy humidifer?
Bleach is a good way to clean a mold humidifier or you can buy additive expecially made for humidifiers to fight mold.
Dec 20, 2009 | Humidifiers
I have discovered mold growing inside the chamber that mist emits from. how do i thoroughly clean it. how often should i clean it?
The best thing around your house is bleach, it kills mold dead. Mold needs moisture, food, air so removing any one of those will kill it. I would try cleaning with soap and water with a little bleach every two weeks and see how it goes, they increase or decrease the time between cleanings as determined necessary. Remmeber bleach stains anything it comes in contact so be careful with it.
Good Luck,
Gilshultz
Dec 01, 2009 | Vicks V4500 1 Gallon Humidifier
How do i clean the mold off my humidifier?
Apr 02, 2009 | Duracraft DWM-250 2.5 Gallon Humidifier
Need to clean humidifier
Put two tablespoons of clorox in the water now. Then everytime you refill it add one tablespoon of clorox. Do not over do it. If it smells like strong clorox, reduce the amount.
Mar 20, 2009 | Crane Panda 1 Gallon Humidifier
Vicks Warm Mist V745A 1 Gallon Humidifier Logo
212 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
