Question about Whirlpool Washing Machines
Actuator and rubber level replacement. Model WWC 22 is having trouble with spinning clothes as it continuously wiggles and not spinning.
3 Suggested Answers
catriver
  • 878 Answers
SOURCE: Trouble with constant spin
If your Kenmore is agitating and spinning at the same time then you have a gearcase problem. The gearcase is warranteed for 5 years part only. The labor would run around 133.00 Your model is a direct drive washer and changing out the gearcase is not that bad of a job. Part number for the gearcase is 3360630. Catriver..post back.
Posted on Jul 31, 2006
  • 84 Answers
SOURCE: Clothes still saturated with water after spin cycle
Check pump is not jammed or pump / drain filter is not blocked , if so clean /free and re-try , may not require any parts . refer to handbook for location of filter .
Posted on Nov 09, 2009
Maytag top load washing machine repair
It sounds like your Maytag (now owned by Whirlpool) Actuator needs to be replaced. Last year our Maytag Centennial top loading washer Model MVWC300XW0 would not drain all the water and cloths would be soaking still. Doing some online research, I came across some very helpful video regarding replacing your Actuator.
The only thing I would recommend to future installers is get your Technician Manual located just inside the case (front panel) first of your Washer. The Technician Manual is taped inside your washer in a plastic bag. Once you replace this Actuator part, I recommend that you run the Calibration cycle on your washer. It is needed anytime you replace a motor, motherboard or pump.
Here are two videos describing how to change/replace the Actuator but these videos are basically for the MVWC300XW0 model. I'm sure if you search for your model, there will be other videos as well.
Two videos on how to replace your Actuator:
1: https://www.youtube.com/watch?v=YVjTY-Hj4jw
2: https://www.youtube.com/watch?v=yTHryoT78pA (This is video that I viewed the most)
Best of Luck!
Jun 05, 2016 | Maytag Washing Machines
Broken oil line, was there a recall?
seat heater and accelerator pedal,
  • TSB #TC-10-010 NHTSA ID #10032630
    • Date Announced:FEBRUARY 22 2010
    • Additional Info:How to Fix
    Summary: TOYOTA SERVICE CAMPAIGN: SEE DOCUMENT SEARCH BUTTON FOR OWNER LETTER. ON CERTAIN MODEL VEHICLES EQUIPPED WITH A 2GR-FE (VE) ENGINE, THE RUBBER PORTION OF THE OIL SUPPLY HOSE FOR THE VVT-I ACTUATOR MAY DEGRADE OVER TIME. THIS CONDITION MAY
    More Information ยป
  • TSB #LSC-90-K NHTSA ID #10032631
    Summary: TOYOTA: ON CERTAIN MODEL VEHICLES,EQUIPPED WITH A 2GR-FE (VE) ENGINE, AN INITIATED PHASE 3 WILL REPLACE THE VVT-I OIL HOSE DUE TO THE RUBBER PORTION OF THE OIL SUPPLY HOSE FOR THE VVT-I ACTUATOR MAY DEGRADE OVER TIME. *PE
2007 Toyota Avalon TSBs CarComplaints com
Jun 26, 2015 | 2007 Toyota Avalon
I have simpson eziset 7.5kg has trouble spinning throws clothes to one side of tub
check that the machine is level
check that the wash bowl is level as a support mount may be failing and the bowl is not level
when it happens redistribute the clothes to a better balance point and re-spin
if it still happens ,seek the services of a washer technician.
Apr 07, 2015 | Simpson Washing Machines
Frigidaire affininty washer. the washer will not spin my clothes it says e20. so i put the washer on spin only and it will spin out mt clothes.
see this causes and fix it. God bless you
Water Level Control / Pressure Switch
his is the most common reason a washer will agitate but not spin. To check this on most , with no water you should have continuity on pins 7&15. With the tub full 7&16 should have continuity. This video walks you thru checking another type of switch.
Lid Switch
This can be the problem for the washer not spinning . Most whirlpool styles this will effect both agitate and spin but some models will still agitate but not spin.This is easy to check. You will need to remove the switch, this varies with model type but the testing will be the same. When the lid is closed the switch should have continuity when the lid is opend the switch should have no continuity. If it differs replace the Lid Switch.
Timer
To check the timer you will need to refer to the wiring diagram or disassemble to access the motor. Check the leads from the timer to the motor when turned to a wash cycle this should have 120 volts. If not replace the Timer, if it does the timer is not the problem.
Motor
To check the motor you will need to disassemble the washer to access the motor. First you can check the motor windings, to do this remove the plug and connect ohmeter to terminals. Refer to the tech sheet or service manual for the proper reading. Check motor for shorts by connecting ohmeter to terminals and motor housing should have no continuity. Connect voltmeter to motor wire connector and check for voltage. You should have 120 volts, if you do and the motor does not run replace the motor. If it does not have power the problem is elsewhere.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to thetransmission. The following video will walk you through the replacement of the Motor Coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise theproblem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Sep 25, 2012 | Washing Machines
MODEL LAT8600AAL WASHER ONLY EMPTIES ABOUT 3/4 WON'T SPIN UNLESS YOU WIGGLE DIAL
Wiggling the dial is making the contacts in the timer actuate, indicating a bad timer. Replace the timer, part number 207379, available at www.appliancezone.com for $94.49 + shipping.
Sep 11, 2010 | Maytag Washing Machines
Maytag clothes washer, with pump and belt replaced in Nov. 2007, clothes were too wet after spin cycle
The start of the spin cycle is dependent on the pump pumpin out water and the later level switch sensing that the water level is low enough. The water level switch has (usually) a clear tube connected to it and is found in the control panel. You will want to check continuity at different times. First you will fill the tub to the highest water level. Then unplug the machine. By screwing in the screw on the water level switch. Scew it all the way in. then you will check continutity. there should be no cont. between green and brown. and there should be cont between green and black or yellowblack. Do this continuity test with the wires off the switch. Once this test is complete, reattach the wires and plug in the machine and set the timer on spin or drain. When the tub is pumped dry, stop the spin cycle and unplug the washer and do the continuity test again. This time you should have continutiy from green to brown. and no continuity from green to black or yellowblack. Now when i mention the colors that means the placement where those wires were. Make note before you remove them so that you can get them back to place. If you do not get these readings, the water level switch is bad, or there is a leak in the air pressure tube leading to it. At that point I would replace the entire switch and tube. I wish you the best of luck.
Apr 21, 2009 | Washing Machines
Knocking sound in the spin cycle off balance.
The motor switch that is mounted on the motor may need replacing. The knocking could mean that the "run" winding is cutting off momentarily, and running on the "start" winding of the motor. I dont know about a 22 year old model, but in most "near modern" machines, the switch has a plastic actuator that is pushed when the motor obtains near-run speed, that plastic may be worn or the actuator part on the motor may be at fault. If you replace the motor, you usually get this switch as part of the deal.
Feb 05, 2009 | Maytag Washing Machines
Jul 31, 2006 | Kenmore 22622 Top Load Washer
Washing Machines Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
