Unit puts out cool air but it is not COLD and does not cool the unit. It constantly cycles on and off despite the fact that the unit never cools the RV to what the thermostat is set. The Bed Room unit is identical. However, it seems to work fine.
    President:
  • 3,773 Answers
Check inside and outside coils for cleaning with coil cleaner spray
Check capacitor(remove and take to appliance parts dealer. They will checkit)
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 02, 2010
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
Unit will not blow cold air after starting up for first time this season
That's because this unit is only designed to cool a room to approximately 75 degrees. http://www.fixya.com/support/p114531-delonghi_pinguino_pac_700t_air/manual-1811/page-2 It's not supposed to make the room cold, just comfortably cool. It automatically switches off of Cooling when it achieves this. If you want it cooler, you'll have to get a traditional air conditioner unit (like a window unit).
Sep 01, 2007 | DeLonghi Pinguino PAC-700T Air Conditioner
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
Samsung rb215labp freezer cools but refrigerator wont cool
check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required
May 28, 2014 | Samsung RB215LASH
I live in a very small one room studio,and have a comfort aire window unit...air and heat.The heat works real well,but in the spring and summer,I would set the unit on the coldest setting.I can hear the...
Lets look at the output of the system first. Take your square footage of the area you are trying to condition and times it by 15. We try to get 15 Btu's per square foot of air conditioning. If your area is say 10 by 15, you have 150 square feet; times it by 15 = 2250 Btu unit is required. If you have a 5,000 Btu unit, it should be more than enough to cool the room. If this is correct, the problem may be because you have the unit set for Dry. In Dry mode, the compressor will cycle less frequently than if on Cool. If in fact the unit is on Cool, you may need to lower the temperature setting to fool the sensor from turning off the compressor prematurly. If you still can't cool the area, your unit has an issue with either refrigeration or air circulation and will need to be serviced.
Apr 09, 2011 | Comfort-Aire Heating & Cooling
Hi I have a Daytek 12000btu. The air con is blowing out cold air but despite having all windows and doors closed the cold air is not circulating around the room. Its only cold when you stand in front of...
air filter, cooling coil and blower wheel are full of dusty. Clean it. And also check RPM of indoor fan motor. If less replace capacitor. If rpm o.k, after clean run the unit. Thanks.
Feb 09, 2011 | Daewoo DSA-122L Air Conditioner
My Home Ac Unit Is Not Blowing Any Air
This sounds like the fan not turning during cool. You will have to check the fan relay for power during the cool cycle. The fan relay is run by the low voltage side, but still there is hi voltage present. When in heat the power goes thru the relay on one set of points then in cool goes thru the opposite side. You should have a digram present, and then on the main circuit board there is a code light. Check the light for blinking or (flash) read the bottom of the board for the code ( very small print)
May 17, 2010 | Goodman CKL24AR24 Air Conditioner
After a cooling cycle, when the thermostat call for more cooling, it take up to 5 minutes after the air handler starts for the compressor motor to restart. The top fan operates on the outside unit, but...
No, this cycle cannot be shortened due to the simple fact that this feature is in place to protect your system. Even if it could be, I wouldn't recommend it.
Mat
Jul 17, 2009 | Coleman Heating & Cooling
Heated air coming out when unit is in Cool Mode
Heat pumps are sometime constructed to "Fail in the heat mode." It could be either the t'stat or the reversing valve. Be sure the t'stat is wired correctly. Usually the"O" terminal is for the reversing valve on the outdoor unit.
Mar 28, 2009 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
