Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
My may tag referigator not colling...frezer seems to be working fine
    President:
  • 1,891 Answers
Look in back of freezer for ice / if so you need my help not a un comon problem as the defrost system has failed . mm
Posted on Sep 02, 2010
No temp lights on fridge or frezer panel.light on in frezer not in fridge
Try cycling the power. Switch of the fridge at its isolator (or wall socket), leave for 1 minute and switch on again.
Consult your owner manual for guidance.
If still under warranty, contact your dealer.
Apr 16, 2014 | Refrigerators
There is frost buildup on back wall of frezer fridge or frezer dont get cold enough
my fan blade had slipped down and was rubbing makeing a noise and fine particles of white dust was at the rub point. Pushed the fan back up drop of super glue and lubricated the motor. works great!
Jul 27, 2010 | Hotpoint (HSM25IFTSA) Side by Side...
We have a hotpoint refrigerator. The Frezer seems
There is a part called a defrost timer, it is usually the most likely culprit in these situations. Hope this helps
Oct 07, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
No power
Fridge is 60% nit working.The freezer is -20%.Circuteboard was replaced and defrost controler.Referigator does not work.Service technition has tried three times to repair.Referigator is 14months old.
Aug 05, 2009 | LG LFC23760ST Side by Side Bottom Freezer...
Compressor switch burned out, replaced it but now the refrigerator is not getting cold. frezer seems to be working fine. where should I look next?
Is the indor fan working or not.To look for indor fan is working or not go to frizer side and look for cold air to came out, if not i think you must have defrost thermostat broke to
Aug 03, 2009 | Kenmore Refrigerators
My Samsung side-by-side refrigerator is not cooling.
your condenser is not working you likely had the fan go out or not enough air flow.
these units have a problem and Samsung refuses to recall them. get a different brand
Jul 20, 2009 | Samsung RS2630WW Side by Side Refrigerator
Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Roper Side-by-Side Refrigerator Problem
Try changing the relay (in black box) on compressor.
Apr 26, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Frezer does not seem to be working in the cold
s it should the ambient temperatures that you said are way to cold to expect the freezer to operate properly. move it indoors and or contact the manufacture and see if the have a kit to put on the unit to work properly.
Jan 10, 2009 | Freezers
Frezer working fine but fridge not cooling
Mo, open the freezer door and look for the model tag. There should be a manufacture date on the tag. The product has a 2 year complete warranty, 5year parts and labor on the sealed system and 5-12 years parts only. The factory number is 800-222-7820 and maybe able to tell you when it was installed, They may walk you through a couple of items to tell you what was happening.
Nov 21, 2008 | Sub-Zero 690 Side by Side Refrigerator
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
