Question about Refrigerators
I have a 7 year old 21 cubic ft., top freezer Frigidaire refrigerator. There is always water dripping down the back of the inside of the fridge, which then pools in the well in the bottom. It seems like there is a tube in the back of the freezer which is supposed to send the water out the back to a pan, but it is staying inside the fridge. Sometimes the water also pools up on the shelves.
  • 4,793 Answers
Syringe the tube with clorine bleach.dry out the interior then cover all food to cut down on condensation,although most freezers are "frost free"the fridges ARE NOT.so most of the problems are condensation.....
Posted on Sep 02, 2010
I have space for a 64in.height,32 in. width,26 in. depth refrigerator. What size in cubic feet should I get?
Well, these measurements will limit the outside of the cabinet. The size of fridges almost always refers to the inside capacity. The relationship between the two varies a little from model to model. For instance if you get one with an ice maker, the inside capacity is less, but the outside is the same as the same fridge without ice.
You could buy for instance a Whirlpool 14 cu ft top mount freezer model, which is 63" h x 28" w x 26" d. The 18 cu ft is too big. Another possibility is the Frigidaire 14 cu ft.
Nov 13, 2015 | Refrigerators
How do I work out the storage capacity in liters for my fridge Frigidaire FPC523TEW1?
Hello Howard;
My name is Peter. I am a retired field service refrigeration technician.
Near the top side wall inside your freezer there is a label that gives you the exact cubic feet. Your model number has a rounded off cubic of 23.
So,
23 Cu.Ft. x 28.316 = 651.218 Liters.
Mar 13, 2015 | Frigidaire Freezers
What is the cu ft for frigidaire upright freezer mfu21m3gw1
Thank you for your post, friend!
I see you would like to know the cubic footage of your Frigidaire freezer. Based off the model number you have provided it appears that you have a 21 cubic foot freezer. Hopefully this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Freezers
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Water pooling at the bottom of kenmore fridge
I had a Kenmore fridge - about 20 years old when I replaced it this year. It used to do the exact same thing especially in warm/hot weather. What it is is the water from the freezer defrosting. There should be something on the back near the top, inside the fridge sticking out - a tiny little tray sticking out and it may also be part of supporting one of the shelves, I can't remember. Anyways, water from the defrost pools in there and is supposed to evaporate, but it gets clogged with gunk and the water spills out and runs down the back of the fridge down to the bottom. Get a pipe cleaner or something and poke it into this hole and clean out the pipe to the hole isn't blocked. This is all inside the fridge, not outside, on the back panel outside. That's the best I can do to describe the solution - it's an easy fix you can do yourself. Good luck!
Jan 01, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water inside refrigerator
Even though it doesn't seem like it's coming from your freezer, morre than likely that's where it's coming from. At the back of the fridge there will be a drip tray that actually catches the water from the thawing freeze. One way to avoid access water is to simply turn down your freezer and fridge. Usually if they are number 0-10, both frigde and freezer should be set on the 5 level.
Aug 31, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Accumulation of water in bottom of fridge
You probably need a new door deal for the freezer. When you cet too much condensation in the freezer, it drains down the back of the refrigerator section during the defrost cycle. Check under the produce bins for a drain. If you don't have one, you're not alone. I used to have have to wipe mine out every other day until I finally replaced the seal.
Feb 02, 2009 | Frigidaire FRT21G4B Top Freezer...
WATER RUNNING OUT FROM UNDER REFRIGERATOR
If the floor of the freezer is full of ice, your defrost water drain tube is clogged. Remove the ice in the freezer bottom, find the top of the drain tube inside the freezer near the top of the ramped up area, about the size of your index finger and blast hot water through it with a turkey baster. About 4 cups of good hot water but not boiling
Dec 20, 2008 | Whirlpool 19.8 cu. ft. Side-by-Side...
Refrigerators Logo
188 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
