Question about Amana Refrigerators
The ice maker is no longer making any ice. - Amana Refrigerators
  • 3 Answers
It sounds as if your water line is frozen. Completely turn off the refrigerator and freezer and let it sit for about 1 to 2 hours. This is enough to start to thaw the unit, but not long enough to hurt your food. Turn it back on and see if it works. If not - go to Plan B.
Posted on Sep 02, 2010
  • Amana Master
  • 8,220 Answers
Do this simple test:
More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
My Whynter UIM-155 ice maker used to make alot of ice quickly. Now, it does not make very much ice and it takes a long time? What should I do?
look at the condenser coli to see if it is dirty if so clean it. Dirty coil will cause it longer to make ice. also make sure nothing is blocking the condenser return.
Aug 20, 2013 | Whynter UIM-155 Stainless Steel Built-In...
Our Marvel icemaker was working great then it starting making ice at a much slower pace. It is not make ice no where near as fast as it was. What could be the problem?
Could be a dirty condenser coil, blocked return air, if the ice machine is in a warm environment it takes longer to make ice, water temperature if it is warmer it will take longer to make ice. if water inlet valve is letting water seep buy during freeze cycle it will take longer to freeze.
Dec 17, 2012 | Marvel Appliance Ice Maker
Ice maker is no longer making ice help!
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 06, 2010 | Sub-Zero PRO 48 Side by Side Refrigerator
My whirlpool ed5phexrb00 icemaker no longer works
Ice maker does not seem to have water flowing to it.
Mar 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
The ice maker doen't make as much ice as before in the ice dispen
level the refrigerator. water pressure may be too high 65 psi max. check if there is a chunk of ice stuck, diverting the influx of water, cubes should not exceed 7/8 in thick or tall at widest point. no axel mark on top. fill should be no longer than 7.5 seconds.If longer then 7.5 sec, replace modual
Aug 24, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
The ice machine is no longer taking in water to make ice
Sometimes the valve on the water line becomes plugged and can no longer supply water to the refrigerator. The other options are that the ice maker could possibly not be supplying voltage to the solenoid valve on the rear of the fridge, or the solenoid valve could be bad itself.
Mar 13, 2009 | Refrigerators
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
LG Ice maker
You may have a broken ice maker and it needs to be replaced. You will need to have a qualified LG technician assist you.
Apr 20, 2008 | LG LRSC-26930 Side by Side Refrigerator
No ice
see if there is a device the water goes into then another tubes come out and goes to the ice maker, that middle part is bad.
Feb 06, 2008 | Estate TS25AFXK Side by Side Refrigerator
Refrigerators Logo
59 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
