Question about Logitech Cordless Mouse
Mouse not working, red light is out, green light on tops flashes then goes out. installed new batteries, restarted laptop. Less than a month old.
  • 3 Answers
Press the reset button inside by the battery, and then also on the bottom press the connect button.
Posted on Sep 02, 2010
Green flashing light
Try this, take batteries out and the receiver, leave out about a half hour, then reinstall them, make sure after installing batteries to hold mouse in front of receiver and click to the light comes on. good luck!
Feb 06, 2014 | Logitech Cordless Desktop Wave Keyboard...
RYOBI CHARGER RED AND GREEN FLASHING LIGHT
My charger blinks red and green but I've literally only used my chainsaw 4 times. It's less than a year old. It won't charge the battery. What could be the issue? Or can I take it back to home Depot and use the warranty? Any help will be welcome.
Jan 04, 2012 | Ryobi Multi-Volt Battery Charger
I have aenigma wheel chair with a shark contoller when you switch it on all lights come on then only one left hand light flashes red thanks Stuart
Stuart iy\ts indicating low battery voltage charge the batteries and see if it goes away if it doesn't then the batteries need replacing or your charge is not working correctly If after charging overnite when you get up in the morning the charger should have a green light on and the battery level should be full. If after just a bit it goes to the red flashing light then your batteries are bad and need replacing. If the chair is less than 6 months old then the batteries are under warranty and your provider(where you got your chair) must replace them at no cost Hope this helps
Mar 20, 2011 | Ctm HS-2800 Power Wheelchair
Mouse has flashing red light. What should I do?
Does the mouse still work? It could just be the low battery warning, ensure that it goes to green when you put in on charge (or put new batteries if its not a rechargeable one)
Oct 29, 2010 | Logitech Cordless Mouse
I put in new batteries but no luck. No lights go ...
Answer:
With the buttons toward the top:
The top LEFT slider button is for power. Slide toward the outside for ON. Light on top of mouse turns green after about 1 second, and stays green for about 10 seconds (assuming the batteries are okay). When the batteries are failing, it blinks red.
The top Right PUSH button sends a connection signal to the PC. When pressed, the indicator light on the top flashes green and red, indicating the special connection signal.
This is the mouse side of the equation (good batteries, slider turned on, connection button pressed and released.).
NOW: the PC must have a working receiver, with drivers installed, and Bluetooth software installed. it sould detect the mouse. If it asks for a passkey, say none (mouse doesn't need passkey).
You should not need Microsoft Intellipoint. it doesn't have a configuration for this particular mouse model anyway.
Good Luck!
May 21, 2010 | Microsoft Bluetooth 5000 Mouse
Ryobi 18v lithium battery won't charge
sound to me like you have a bad battery, a lot of ryobi batterys don't last like they should i have had the same problem, but my battery was less than a year old and i took it back and they give me a new one.
Mar 15, 2010 | Ryobi 3-piece 18V Drill / Circular Saw /...
Wireless mouse stopped working. green light works
This can happen when the battery's are starting to die. Replace the batteries and then test the device again.
Oct 09, 2009 | HP Wireless Optical Mouse
My computer recognizes the mouse, and connects to it, but the mouse doesn't work. It is flashing green then red on the battery indicator.
I had the same problem and it turned out that it had nothing to do with the batteries.
Go to the bluetooth indicator on your computer and disable the device. Then restart your computer.
When the computer is restarted set the mouse into "discoverable mode" which is the flashing red/green thing and it should find your computer.
This worked for me!
Jul 11, 2009 | Microsoft Bluetooth 5000 Mouse
Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
Feb 24, 2009 | Microsoft Wireless Notebook Optical Mouse...
Logitech Cordless Mouse Logo
646 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
