Question about Mitel Superset 420 Corded Phone
Mitel SX 50 HELP
ALARM code bell will not stop!!! Message says "STATION RING GROUND FAULT 0" help THIS IS MAKING ME CRAZY!!!
  • Marsh01 Jun 29, 2008
    The alarm keeps beeping even we press *32 please help us out if possible now
3 Suggested Answers
micromaster
  • 3614 Answers
SOURCE: I have a mitel sx-50
try to remove the battery and reset the unit... this could be an error on result.
Posted on Jul 25, 2008
SOURCE: Need to have a Mitel SX 50 Phone System ring on cordless phones
You can switch to "night" mode on the console and the incoming calls should ring on the cordless. try it.
Posted on Dec 17, 2008
Why my mitel sx-50 shows message on console no communication?
The phone line between the SX-50 console and the main control is disconnected or the console may need to be rebooted (unplug the phone line then reconnect it). If this doesn't solve it then contact your PBX system support person.
Jul 14, 2014 | Mitel Lands Phones
Mitel SX-50 phone console keeps ringing for no reason.
first make sure it is not a line problem by disconnecting the phone line when you get the rings, then make sure it is getting proper power to the unit. if it does not have electric plug look for batt in unit and replace. If unit is dirty, gummed up try blowing out with air, before giving up on the unit. good luck
Jun 02, 2014 | Mitel SX-50 Console White Phone...
Printer queue is full on sx-50 attendant console
This is explained in the SX-50 system maintainer's handbook, 2 copies of which came with your SX-50 when it was new. However, this is a pretty old piece of phone equipment (30+ yrs) and when these systems were originally set up by outside service companies, it was not unusual for them to take the manuals so that customers would not be tempted to tamper and would call the service co instead. However, all is not lost. There is a very good Mitel support group on Tek-Tips (www.tek-tips.com) On tek-tips the Mitel forum is under Home->Forums->Wiring Closet->Phone Systems->Mitel Networks Solutions Forum. You will need to register in order to post. Hope this helps.
Apr 19, 2014 | Mitel Superset 4015 Corded Phone
My Mitel SX-50 dial pad on console does not work. Help
Look for a button on the console that is stuck down. This will cause the problem you are describing. If this is not the case, you need to get with a Mitel vendor to get the console repaired and refurbished.
Jul 10, 2013 | Mitel Lands Phones
Set an alarm to automaticly wake a customer. The
press function key * and then 32 to stop that alram. *32, give me reply if you have question.
Apr 07, 2010 | Mitel 9104-001-000 Power Supply SX-50...
Mitel sx-20 trunk interrogation function codes
From a DTMF station set installed as the test line on equipment #1, go into trunk group programming (Command #66)
The SX-20 display will show programming registers.
A B C D E F G H
A,B = Trunk equipment Number (1st trunk should be displayed)
C = Register 1
D = Trunk Group Membership 0 = Incoming only
1 = Group 1
2 = Group 2
3 = Group 4
4 = Group 4
E = Trunk Type 0 = Standard CO Trunk
1 = Dictation Trunk
F = Reversal Meaning 0 = Not Incoming of Disconnect
1 = Incoming Call
2 = Incoming Call or Disconnect
G = Disconnect Timing 0 = 60ms
1 = 500ms
2 = 1.5 sec
3 = 4 sec
H = Start Type 0 = Loop Start
1 = Ground Start
Move to the appropriate register using the ENTER/NEXT function (star key).
Change the data as required.
Exit programming (# key)
Hope this helps!
Mar 25, 2009 | Lands Phones
Nov 11, 2008 | Uniden 5.8GHz Cordless Phone
Voice Mail
If you have the SX -200 series 410 then here is your manual.
http://edocs.mitel.com/UG/EN/SX-200_SS410_ug_en.pdf
If you have the SX -2000 series 410 then here is your manual.
http://edocs.mitel.com/UG/EN/2k_410.pdf
It looks like from reading them though, that your IT department (PBX Administrator) will be the people you will need to contact to reset your code. Or if that does not work for you then I would contact Mitels customer support and see if they can walk you through it.
http://www.mitel.com/DocController?documentId=10095
Hope it helps, and let me know if you need more help or information.
Thanks!
Oct 31, 2008 | Mitel Superset 410 Corded Phone...
Mitel Superset 420 Corded Phone Logo
189 people viewed this question
Top Mitel Lands Phones Experts
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a Mitel Lands Phone Expert? Answer questions, earn points and help others
