Question about Canon Office Equipment & Supplies
Error code 5100 on canon mx860 - Canon Office Equipment & Supplies
SOURCE: Error 5100 on my canon mx 310.
the 5100 is the carriage error and can be caused by 4 different sensors. First off the "Timing Strip" that passes through the back of the Carriage Assembly can be contaminated with ink spots and this needs to be cleaned. Open the cover and use your flashlight to examine the timing strip as much as you can see. You really don't have much access to this strip unless you remove the covers,..and doing that is considerable work. The other items that can cause this error are the sensor inside the carriage unit, the drive motor for the carriage asm, and of course the main logic card. However, 99.6% of the time it is the Timing strip which is easitly contaminated with splattered ink.
Posted on Apr 02, 2010
SOURCE: canon pixma mp530 problem error code 5100
i had the same problem. aall i did was open the printer up and moved the thing that holds the cartridges to the middle by hand. mine seems to be working fine. post again if its still not working.
Posted on Nov 16, 2007
SOURCE: canon pixma450 printer error code 5100
go crazy and hit it will work relly i tried it
Posted on Nov 20, 2007
IB4G2008
  • 3587 Answers
SOURCE: canon pixma mp600 error code 5100
try this solution..from fixmyprinter.com
This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 02, 2008
Had to move the printer cartridge and shut down three times, but it finally kicked in and started working again. Don't give up just trying it once.
Posted on May 27, 2008
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
Canon mx870 printer b200 error
http://forums.usa.canon.com/t5/Personal-Printers/Canon-MX860-repeats-B200-error-code-brought-it-back-to-store/td-p/489
Feb 19, 2014 | Computers & Internet
Canon mx860 - had an error code C000 and now a day later 306A
Error code C000. Cancel printing, and turn off the machine. Then clear the paper jam or foreign object that is preventing the Print Head Holder from moving.
For more information about the error code C000, can be read here Canon Support and Downloads
You read, the bottom of the page
Sep 23, 2011 | Canon PIXMA MX860 All-In-One InkJet...
Problem 5100 in my canon mx860. Help
What do you do with error c1000 on a canon MX860?
Feb 28, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
Hello, I have a Canon Pixma MX860 all in one copier printer that just began to display error #5100. All the ink cartridges are full. How do I reset the printer so that this error will not be displayed...
Turn off printer.
Remove both the cartridges from the printer. Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches.
Return the cartridges and turn on the printer.
Error 5100 means that the cartridge can not be detected by the printer.
Hope it helps1
Dec 18, 2010 | Microscan MS-860 Fixed/Industrial Barcode...
555 people viewed this question
old marine
old marine
