Question about Maytag M6Y18F7A Air Conditioner
I have a maytag M6Y18F7A air conditioner.The control pad needs to be replaced.I have looked everywere online and cant find it.Any suggestions where I can find it?
  • 22 Answers
Appliancefactoryparts.com. I have purchased 2 controllers from them
Posted on Sep 16, 2010
    President:
  • 3,773 Answers
Try
www.marcone.com
if they don't have it you can forget it or call the MFR.
If this was helpful please rate me.
IMUFO2
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Sep 02, 2010
AC UNIT TRIPS THE BREAKER WHEN PLUGGED DIRECTLY TO WALL OUTLET AND FLIPS THE SURGE PROTECTOR TO OFF ALSO. WALL OUTLET WAS REPLACED AND STILL THE SAME ISSUE.
The problem might be in the compressor or fan motor. The compressor pulls a lot of amps, and much more if it's jammed or binding. The fan motor will do the same.
Aug 28, 2013 | Maytag M6Y18F7A Air Conditioner
How to fix squeal in a Maytag airconditioner
no belt. should be a direct drive motor. most likely bearings in motor going out. you will have to replace motor at some point it will lock up. if it has oil ports you can try oiling to prolong but will eventually stop working.
Aug 30, 2012 | Maytag M6Y18F7A Air Conditioner
My 18000 btu Maytag window air conditioner does not cool. The compressor kicks on in an attempt to cool but no cool air comes out.
Hello my name is Heath it will be my pleasure to assist you. One thing I can suggest is try plugging the air conditioner into a surge protector.
Jul 01, 2010 | Maytag M6Y18F7A Air Conditioner
When running it squeels
sounds like the bearings are going out on the blower motor...........needs replacement.................
Jun 26, 2010 | Maytag M6Y18F7A Air Conditioner
Maytag M6Y18F7A Air Conditioner troble light turns off
you have to open the unit up or atleast see if the fan is failing. The blower motor is usually a double shaft and cool the compressor and also blows the air across the evaporator. Look for the air to stop blowing then the compressor to shake from overheating.
Aug 12, 2009 | Fedders AEY08F2FCOM Wall/Window Air...
The AC runs on high only low or med and the ac shuts down. What part do I need?
Check to see if your getting the proper voltage to medium and low speed at the switch, if you are then the switch is good and you have an open winding in the motor and it needs replaced to correct the problem, if not then you need to replace the switch.
Aug 02, 2009 | Maytag M6Y18F7A Air Conditioner
I have a Maytag M6Y18F7A Air Conditioner window unit & am having problems w/ the thermostatic control not dropping below 75o. Originally, the unit switched to 67o which wasn't really a concern, but 75o...
This sounds like the control board has malfunctioned. You might have to have it replaced. When you have it on, does the unit switch off at 75o or does it continue to run? Also check the temp of the air leaving the unit, it needs to be below 55o's.
Mar 30, 2009 | Maytag M6Y18F7A Air Conditioner
I am trying to find a motor for M6Y18F7A
Hi Sal,
You didn't mention which motor you're looking for, so here is the condenser motor and her is the dual shaft motor. These links have part numbers so you can shop around for the best prices.
Hope this helps!
SG
Mar 26, 2009 | Maytag M6Y18F7A Air Conditioner
No POWER WHEN TURNED
lol not good , these unit are not meant tobe repaired make sure the outlet is not 220 check breaker or try other outlet.
May 16, 2008 | Maytag M6Y18F7A Air Conditioner
Maytag M6Y18F7A Air Conditioner Logo
166 people viewed this question
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
