Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
The outside of the freezer sides are extremely hot to the touch? Why? Freezing fine on the inside.
  • 21 Answers
The coil normally on b ack of fridges is on sides of freezers under skin it is normal to be warm. The hotter the weather the hotter the skin.
Posted on Sep 02, 2010
2 Suggested Answers
  • 1144 Answers
SOURCE: Nor-Lake t3000 freezer - door HOT
The door frame heater is probably damaged and grounded. Unfortunately, it is still energized causing less than the entire heater being utilized which will cause an extremely hot condition. I would look at replacing it. It is a pain to do but with some patience, it can be done.
Good luck and hope this helps.
Posted on Mar 31, 2009
Idylis 5.0 cu ft chest freezer: why is the outside of my new freezer hot to the touch, while the inside is freezing?
if new and a 5 ltr
check thermostat setting
it takes some time to freeze up unit and contents
motor will run a bit longer then normal
then should kick in on and off with the thermostat
Sep 13, 2016 | Freezers
The freezer is hot on the outside
Make sure the evaporator coils on the back or underneath near the compressor are clean. If there is a fan near the coils make sure it's running.
Dec 09, 2009 | Whirlpool 14.8 cu. ft. Chest Freezer...
Walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
Sep 08, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Mar 27, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
Freezer
The condenser or high side is built into the side walls on these modern freezers and refrigerators in many cases. It is normal for the outside walls to be hot when the unit is working. Frost on the inside of the sealed packets of food is from the moisture content of the food. Running the temperature setting to cold will accelerate the moisture freezing to the inside of the food packets. This also is a normal condition.
Sep 15, 2008 | Freezers
My freezer is hot!
It is normal for the freezer or fridge walls to be hot sometimes, some important points are to make sure that there is enough ventillation around the fridge/freezer, especcially the back, so that air can circulate around it freely. Also maybe just check that there hasn't been anything fallen down the back blocking the vent, and that there isn't a dust collection or anything. Otherwise as far as I know this is normal.
Aug 19, 2008 | Frigidaire 16.7 cu. ft. / 473 liter...
Freezer is freezing but the outer wall are extremly hot
This is a normal condition.  The condensor coils are in the cabinet and their job is to remove heat which is why it is hot.  You will want to make sure the freezer isn't in a tight spot where air from the room can't flow across it.  Without good air flow it will become too hot and not cool properly and lead to the compressor failing too soon.
Oct 13, 2007 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Outside surfaces of freezer very hot to touch
it should be warm to the touch but not so hot you cant. and also depending on how long the freezer is running and how warm it is where the freezer is will effect how hot the outside is. the reason the outside of the freezer is hot is because thats how the freezer releses its heat from the refrigerant. the longer it runs or the harder it has to work the more heat it has to hive off. so unless the freezer is not cooling there is nothing to worry about.
Aug 07, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezer problem
if you don't hear it running for extended periods of time (more than 15 minutes) without stopping, and if it does not immediately re-start once it does stop, and if it is extremely hot climate outside (85 F and above), then yes, this is acceptable.
Jun 08, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
892 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
