Question about GE WBSR3140DW Top Load Washer
We are experiencing this problem recently when we do the laudray. The cold water came out very little, but the hot water is running as usual. I would like to know is this a problem of the washer or the plumbing. But so far all the water plumbing looks fine to us. It is only when we use the washer then this problem came out. Could you help us and do you know what was the problem? Thank you.
    Problem Solver:
  • 7 Answers
There are 2 hoses behind your washer that look like garden hoses. If you run your washer for a minute on the hot setting, one of them will heat up. That's the hot setting. The other hose is the cold one.
First make sure the valve for the cold one is all the way on. If that doesn't solve the problem, you might want to try turning the valve off, then disconnecting the cold hose. Get a bucket of some kind and turn the valve back on and see how fast the water comes out of the hose when it is not connected to the washer.
Posted on Sep 02, 2010
  • GE Master
  • 8,220 Answers
Remove them hoses and clean or discard the inlet screensWe are experiencing this problem recently when we - e2d02ed.jpg
No cold water,only hot
Good Afternoon Leonard, thank you for your inquiry! If the washer was recently installed or moved to a different location, confirm that the hoses are connected correctly. Otherwise, the unit may be experiencing a communication issue with the control not responding accordingly or have a faulty water valve. At this point, I would recommend having a service technician to diagnose the problem before investing in unnecessary parts. Experienced techs also usually warranty their labor just in case something else is the root cause of your initial problem.
Aug 27, 2013 | Frigidaire 14 Cycle Tumble Action Washer
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a really old maytag A606 washer. There is a terrible knocking sound when i try to fill the washer with cold water. I switched the dial to a hot wash, and it works perfectly. Do i need to replace the...
Have you taken the hoses off and checked to see if there is a screen in the hoses?............or on the machine itself its a longshot but usually there are little mesh screen filters either in the hoses or on the machine itself. If its knocking its either dry (no water) or the solenoid is going bad.
Cheap fix possibilty get a Y connector hose and you can mix your hot and cold water in there then just feed it through the hot water side. Or just hook your cold water hose up to the hot water side and just wash with cold water. If you are looking to just get it running and save money.
A couple thoughts anyways
Aug 23, 2013 | Maytag SAV4655A Top Load Washer
My Limited Edition Kenmore Electronic Fabric care washer is not filling up during the wash cycle and will not run the rinse cycle. I recently changed the hot and cold water hoses on the washer.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 07, 2011 | Kenmore Washing Machines
2 yr old Whirlpool duet washer,suds and now f35 codes. Also when put on cold water i can only get hot water ?
the only reason you would get hot water on the cold setting is if the water lines have been crossed.you can usually clear the cosde by running nothing but clean water through the wash cycle and then use a little less soap.on the next was cycle.unplug the unit for a little bit then wait awhile and run the washer empty.
Nov 17, 2010 | Whirlpool Washing Machines
I have hot water for a minute then it goes to warm. I took off the 2 wires on each element and I have 15 ohms on the top and 5.5 on the bottom. Is my bottom element bad?
Sounds like bottom element may be bad but usually reads open circuit if bad. Also tan k would run about 8 gallons hot water then go cold. lots of warm water usually means bad dip tube.
Check if tank is hot at bottom element when not used for a while. If bottom element is still cold then bad element.
If bottom element is hot - (all water in tank is hot then you have a bad "dip tube" This is allowing incoming cold water to mix with outgoing hot water. The dip tube is usually A part of the cold water nipple or B located under the cold water inlet nipple.
Jan 18, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
125FX (with FXhood) turns off while in use
may be overheat stat or fan check little hose at fan area for pinhole best of luck
Oct 19, 2009 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
We have a customer that has a 751od who says at times thier water gets cold for a few seconds. No error codes on the remote. They claim it does it at different fixtures. Everything checks out from water...
A few things you should check:
1. Cross Connections - this occurs when cold water leaks into the hot water system through a fixture. In order to check for a cross connection: 1) turn off the cold water to the tankless 2) open up hot water fixtures in the home. The water should shut off at all hot water fixtures; if there is a continuous flow of cold water, then you have a cross connection. The most common place to find a cross connection is on old shower cartridges.
2. Ask the customer to check to see if the burner indicator is continuously lit during operation.
3. When the water goes cold at one fixture, try another near by fixture to confirm it is also cold there. If its hot at one fixture but not the other, then you have some issue with you plumbing. Tankless heaters can't pick and choose which fixtures to deliver hot water to.
4. Tankless water heaters all have a minimum flow rate that must be maintained in order to continually fire (.5 gpm for Noritz). Ensure their hot water fixtures flow at least this amount, or that the customer isn't mixing too little hot water at their fixture.
5. If they see the cold spurt during initial firing, they may be experiencing a cold water sandwich. When the heater moves from a standing state to a firing state it takes a short period to ignite and heat water. During this time it will be passing cold water through the system. Usually this cold water mixes with hot water in the line as it travels through the plumbing system, but if their fixture is very close to the heater, there won't be enough time to mix.
6. If debris has gotten into the flow sensor, this can prevent the unit from registering flow and cause intermittent firing.
Aug 27, 2009 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
The dehumidifier is blow cold air
Is it collecting water? The air coming out the back top half should be cool/warm. It will be a little warmer at the bottom near the compressor.
Apr 07, 2009 | Kenmore 54701 Dehumidifier
Kenmore Top Loading washer gets very little cold water
You could try reversing the water lines and see when you select hot if cold comes out strong. If it does not then it should be the valve. If it comes out good in reverse, it could be the tempature sensor. Here is the link to parts and diagrams.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11023032100&productCategoryId=0153200&brandId=0582&modelName=WASHER&diagramPageId=00003&componentDescription=REAR%20PANEL&documentId=P0110152&backToLink=Return%20to%20Sub%20Components%20list
Mar 04, 2009 | Kenmore 24032\24036 Top Load Washer
GE WBSR3140DW Top Load Washer Logo
21 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
