Question about Campbell Hausfeld PW2102 Gas Pressure Washer
My pressure washer will not pump the soap, when you take the pipe loose from the handle it pumps out when you hook it back to the handle it quites pumping
    President:
  • Campbell Hau... Master
  • 1,383 Answers
Most pressure washers introduce soap into stream of water by the siphon method. In order for the system to siphon the pressure tip must be changed to one with large opening. Once the large tip is install, the fast moving low pressure water thru the hose and wand will draw-in soap. With the pressure tip installed soap will not be drawn-in. To spray soap and water under pressure use a large container (larger the better like clean 30 gallon trashcan) and fill with clean water and measure of liquid detergent. Use short water hose from with-in container and connect to pressure washer as normal. Keep checking water level so that washer will not run dry. Most pressue washers will **** water in quickly from container, however you can pre-fill the water hose with water to speed things up. Trailer mounted pressure washers use a very large container for water. You can estimate how log the pressure washer will take to use the water by checking the gallons per minute rating of your machine. Good luck
Posted on Sep 03, 2010
Water backs up in the soap reservoir when using the pressure washer
Sounds like a bad check valve or hooked up wrong the soap should siphon in could valve fitting be in backwards, or in wrong place I use a separate siphon valve that fits between pump out let and high pressure hose.
May 10, 2015 | Garden
How to fix power washer with no pressure with out have to buy the hole pump what can i do to fix it
Cover soap inlet and retry. Mine will not pressurize without soap or without inlet covered.
Jul 22, 2014 | Annovi Reverberi Garden
The pressure washer leaks from inside casing letting out water/soap might be affecting pressure of hose?
If your part of the country reaches freezing temperatures during winter, the pump probably froze. This can cause cracks to brass and (especially) aluminum pump heads. It is worth opening up the case; sometimes I find loose fittings (caused by freezing) which can be tightened up and everything is fine. If it is not freeze damage, the check valve may have gone out on the soap injector, causing pressure to back flow through the inlet barb. Otherwise, you may have a worn/leaking pump seal.
This is a consumer (throw-away) pressure washer. If it's not a loose fitting which can be tightened, the unit is probably not worth fixing.
Jul 01, 2014 | Greenworks 1700 PSI 1.4 GPM Electric...
HI. My Comet FWS 4030 works just great and i am very pleased. what i DON'T know is how to draw up soap to mix with the water. there is a big red knob, and another brass adjustment but i have no manual...
The red knob is to regulate the pressure. The soap siphon should be hooked up to the pump at the high pressure outlet and the pressure hose hooks up to it. You do just have to drop the tube into your soap solution but I recommend you dilute the soap down as the siphon usually sucks the solution up fairly fast. The trick to making it work is to use the low pressure, soap tip on your wand. They are black and help fan the water/soap out but give no resistance to the water coming out. If you are using a high pressure tip, usually red, yellow, white or green, there will be too much back pressure in the hose and siphon attachment for it to **** up any solution.
May 18, 2011 | Comet GXD2527G Pressure Washer Pump
The water is going out by the inlet soap fitting, and the soap compartment gets full of water
You will find that the non return valve as stuck inside your pump.If you follow the pipe back to the pump you will find a non return valve which is a ball and spring. Please remove this and replace if required.
this should then stop the water and soap returning back.
Jun 23, 2010 | Honda Pressure Washer PSI 3000
Will not draw soap solution
Follow the pipe back to the pump and you will find a ball and spring inside.This could well be stuck closed if it has been stored for some time. Oil this part and it should draw soap again.
Jun 23, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
It will not dispense the soap.
You need to adjust the nozzle on the end of the lance so the machine will draw chemical at low pressure.
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
WD860 Spitting out water & noisy
The spitting water problem is often caused by the filter assembly in the sump pipe just before the pump getting blocked. This easlily clogs up but is not easy to clean out. Hotpoint do not fit an easy access pump filter to this model but they place the filter into the black rubber pipe that runs from the drum to the pump. When this clogged up the machine empties too slowly and starts to spin when too much water is left in the drum, this forces water up and out of the soap tray. There is a minor design fault as the pressure sensor is attached to the same sump pipe and even when the filter is blocked the suction from pump still drops the pressure on the sensor. So you end up with a drum that has not emptied out enough water but still goes on to spin . The result is niagra falls from the soap tray.
To rectify this you will need to pull the machine out, unplug it, remove the rear lower back panel and dismatle the black sump to pump pipe. Once this is clear you will find the machine runs fine again. Its not an easy jobs and water spills everywear but if you are a keen DIY'r you should be OK. I just cleared mine out and found coins, shirt collar inserts and a large washing instruction label in the sump pipe. Now its clear and the machine has stopped spilling water from the soap dispenser.
As for the noise on spin, check all concrete is firmly fixed to the drum as they work loose
Jan 31, 2009 | Hotpoint Ultima WF860 Front Load Washer
No pressure in my power washer
the problem is that the pump is manufactured with a cheap plastic gear inside the pump which wears out relatively quickly because A: its cheap plastic riding against steel gears and B: they used a very thin oil instead of heavy grease to lubricate the gearbox. Soulution: get a new pump because this one is junk.
Jan 09, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Oct 13, 2008 | RTO 1800 PSI Pressure Washer
Campbell Hausfeld PW2102 Gas Pressure Washer Logo
1,706 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
