Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Left side french door seem to have sagged,and now wants to bind when closing.how do you adjust it upward ??
    President:
  • 1,891 Answers
Ck the cam ( plastic ) it lifts the door and also causes it to close tight . they ware out and the sometimes just brake and fall out . .. part # 12395501 b -- this is a blk bushing . for your model .. mm
Posted on Sep 02, 2010
Door does not close properly and door sagged on the left side
get new hinges and do an adjustment on the door fitting
May 30, 2016 | Kitchen Ranges
Why doesnt my fridge door close?
you should door check if aligned and change the the whole plastic strip around the door
Sep 15, 2015 | Frigidaire Refrigerators
Refrigerator door sags and binds opposite hinge side. Can lower hinge be moved to raise sagging side?
Most likely cause is a worn cam in the hinge. After a while plastic cam wear out a causes doors to sag. Take your model number to Searspartsdirect.com and find the hinge cams and replace. Our went out a few years ago and our door did not shut. We came back 4 days later to a real smelly mess all over our kitchen thanks to these plastic cams. To prolong useful lifetime, try coating the cams with protroleum jelly. Doors should shut when you release the door when open 1 inch by themself. If they do not, the refrigerator feet need to adjusted so front is a little higher than back.
Sep 29, 2014 | Refrigerators
Freezer door does'nt shut all the way
If you notice one side of your Maytag side-by-side refrigerator is significantly higher than the other, you might want to raise or lower one of the doors. The refrigerator door is configured at the factory to be slightly higher than the freezer door. The weight of items on the door shelves sometimes cause the doors to sag slightly inward. Making a small adjustment to the freezer door leveling screws will correct minor amounts of sagging.
Things You'll Need3/8-inch hex head screwdriver 1
Position the refrigerator in the place you plan to keep it, and make sure the refrigerator is level front to back and side to side with a spirit level.
  • 2 Remove the base grille, located below the doors, by pulling from the sides. The leveling screws will be visible when the grille is removed.
  • Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txsYiGQa
    Read more: How to Adjust the Maytag Freezer Door ' eHow.com http://www.ehow.com/how_12111048_adjust-maytag-freezer-door.html#ixzz1txrg7UOa
    May 04, 2012 | Maytag MFI2568AE Side by Side French Door...
    Both the freezer and fridge doors hinge on the right, and the left hand side has sagged a little so neither neither door is sealing properly. How do I adjust the doors to raise the left side of the...
    The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
    Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
    Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
    May 04, 2011 | Refrigerators
    Refridgerator door sags
    Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
    Good Luck!
    Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
    Garage door chain is sagging
    If the chain is adjusted properly the chain will sag slightly on one side when the door is closed and on the other side when it is open. It should not sag enough that it is dragging on the T-rail. You can adjust it at the trolley. If you over tighten it you will hear a clicking sound when the opener opens or closes.
    Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Refrigerator Door not staying closed
    Try to raise by adjust the 2 front footing slightly higher than the back, this will tilt the unit slightly backwards. That will help the door to close back by itself.
    Feb 24, 2009 | LG LRFC25750 Refrigerator French Door
    Right side french door does not stay closed
    I had the same problem - had my local appliance repair shop come by - simple releveling of the unit such that it is tilted slightly back re-establishes things so that the doors will cloe and pull themselves closed. The gaskets are actually magnetized. If the leveling is correct - even upon closing the left door - forcing enough pressure to push open slightly the right side - it will draw itself back in.
    Nov 21, 2008 | Jenn-Air JFC2089HE French Door...
    Drivers side door is sagging
    you could try some door shims in the hinges
    Jun 21, 2008 | 1990 Pontiac 6000
    Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
    128 people viewed this question
    Top Jenn-Air Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
