When I'm on the Dish/CH 3 the TV gets no sound. When I go off to a couple local channels, it gets sound. Other "expert" said to check the SAP and it should be "stereo" but it says "mono" and he couldn't tell me how to change that...
  • 33 Answers
Did you check the voluume control on the sat receiver. it controls the sound level out put from sat only.please rate kindly thanks
Posted on Sep 02, 2010
Can't get it out of SAP mode. tried two different remotes. TV doesn't respond.
1. If you're watching TV via a Cable or Satellite box , then the SAP (Secondary Audio Programming) is activated in the box, not the TV. Check with your TV service provider how to activate/deactivate SAP in their box.
2. Only if you're using the TV's own built-in tuner to watch TV (you're changing channels by using the Panasonic remote for CH up/down), then press the SAP button on the Panasonic TV remote to cycle through the SAP options.
Mar 15, 2016 | Panasonic Viera TH-50PX80U Plasma TV
I think that my TV soney braiva xbr has an issue with SAP but some ch. are in spanish some do not have sound How do i reset this tv?
Press MTS/SAP on the remote (under the number buttons) to go between the 3 options of STEREO or MONO or AUTO SAP. Not all channels will have SAP (secondary audio program). Selecting stereo should eliminate any secondary audio.
Mar 24, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
What channel does the tv have to be on - I have dish network - do I leave the dish off or on and move it to a certain channel?
First check what channel or input your TV is currently on bypowering the TV off then back on and noting the channel or input that appearson screen when the TV is powered on. If you are using a Coax Cable toconnect the receiver to TV1, check the receiver's back panel for the outputname. If your receiver has a "TV CH 3/4 out" (non-ViPReceiver): Tune TV to channel 3 or channel 4, if it has"Home Distribution" output (ViP Receiver): Tune TV to channel 62or 75. If using non-Coax (RCA, Component, or HDMI) to connectreceiver to TV1, cycle through the inputs until picture appears. In your casesince you have the Toshiba XDE500 connected between the receiver and TV, tuneTV and component to channel 3/4 (coax) or correct input. Hope this helps, andhank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Support Representative
Feb 08, 2011 | Toshiba XDE500 Player
Can only get channels 27 and 52 on sanyo 50in tv
is this TV connected to a cable box or satellite dish........if so turn the TV to channel 3, and make sure the source (also on the TV) is set to Cable not AIR... the cable wire from the box / dish is going to the TV (in)
no cable, no satellite how about an Antenna... using this format the source must be AIR and you must let the TV SCAN to lock in all the broadcast channels ... (using any other method there is no need to scan for channels you will only be using one (ch 3)
Dec 20, 2010 | Televison & Video
We move the tv from living room to bed room and we have to change the chanel from 3 to 60 to get the tv to work on dish network, we try to change from 3 to 60 we try evereything whit no result, we call...
Rescan all the channels?Hook the tv and the satalite signal cable in the tv and dish network box correctly check?Go to tv menu.Goto SETUP,pick CH. pick option CABLE enter to rescan all channels.This should have all the channels,belong to the package u order.
Sep 04, 2010 | Televison & Video
No sound on some channels, other channels fine
Your SAP/MTS function is most likely turned on. This feature has 3 modes: Stereo, Mono and SAP. Stereo and Mono are easy to understand, it's the SAP that can get you. SAP stands for Second Audio Production. It is used to provide weather, information or an additional language translation of a program. Some broadcasters simply transmit the mono audio over the SAP audio channel when the are not using it for other purposes. Other broadcasters simply do not use it, which does not give you any audio. Look on your remote for a SAP or MTS button. If you do not see one, look in your TV user menu for this feature. If you are using a cable box, look in the audio menu of the cable box. You are looking for something set to SAP... just change it to STEREO. I hope this was helpful.
Mar 26, 2010 | Televison & Video
Bad picture
I am aware of some TV stations already being switched to their digital stations, even though the government has extended the requirement date to May '09. I noticed on my VCR, when the DST changes; mine doesn't change to the current days as it was made before we changed to 6 extra wks of DST. Does yours do the same thing, or do you set the time manually. If you are not on Dish or Cable and your local TV channels have gone to digital already, that would be the only reason that you are getting the faded/snowy pictures on both. There are 3 ways that you can solve this. My Favorite is #3 for people who don't have cable/Dish. Also, they give you a $40.00 coupon which is the highest amount I personally have seen. 1). sign up for basic cable (if you do, you will more than likely have to look in a higher Ch. # to find your local stations, only a few are being left @ their original Ch. #). 2).Get a Dish. Or 3).You can go to: www.DTV2009.gov and apply on-line for a TV converter box coupon. If you have a copier and fax, you can apply that way as well (must be submitted by 3/31/09.) You can also apply by phone @ this ph. #: 1-888-388-2009 for those who can hear. Deaf (TTY-English): 1-877-530-2634 OR
Deaf (TTY- Spanish) 1-866-495-1161. Good Luck!
Remember your local Ch.'s probably won't be where they are now, unless you are in a small town. If this
helps you, I would really appreciate you telling me what you think of my answer. Thanks so much! Once again, good luck! Good Bye & Good Day. P.S. If I can be of further assistance, give me a shout back, and I'll try to be of more assistance.
Feb 03, 2009 | Panasonic Televison & Video
Sound
SAP is short for "second audio program" and is a way to send a second audio track along with the main one. In many areas stations use SAP to provide Spanish or other language sound for movies and other programs. If you have SAP turned on you don't know it until you tune to a channel where it's being used, and then you hear the other sound. Just turn SAP off using the remote control or TV menu.
Dec 18, 2008 | Sony FD Trinitron WEGA KV-36FV27 36" TV
DISH Network DVR-625 DTV - AUDIO PROBLEM ON LOCAL CHANNELS ONLY
I am probably stating the obvious here but here it goes:
If the 625 is connected to the tv using coax directly try using the RCA jacks to connect directly to the tv. If the 625 goes through a peripheral first, eliminate that peripheral and conect directly to the tv.If the problem exists with different media connections still at the same tv you can remove the coax off of the TV1(3-4) output on the back of the 625 and attach it to the TV2(CH60-73) output.You would then change your tv channel from 3 or 4 to ch 60air or 73 cable(which will be the same channel that TV2 is normally on in the remote room without the 625) Once you are on the right channel you will be able to tune TV1 to your local channel using the TV2 remote. If the audio is good here it eliminates the TV coax input on the TV1 and the coax cable connecting it as the source of the problem. You will have already eliminated any other inputs on the same tv as being faulty by using the other connecting media leaving you with the internal components of the receiver as being faulty. In this situation I know of no recourse except the obvious.
Aug 08, 2008 | DISH Network DVR-625 DTV Receiver /...
No sound on two local channels?
Do you have the original remote? it will look like the one here:http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=B27TF680&brand_pn=RCA_B27TF680&mode=large&uid=11758883061400 If you do not have the original remote you will not be able to switch off the SAP setting, without it as there is a button that controls the sound. when this button is pressed you see where to turn off the SAP setting. Good Luck
Apr 06, 2007 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
Electro Med Services...
