Question about Norcent Technologies DP1800 System
What is the correct DVD to play in player. The DVD I record on will not play in my player
    Problem Solver:
  • 8 Answers
I have burnt a dvd+r and dvd-rw and they both work in my norcent dp1800 dvd + amplifier
Posted on Apr 28, 2013
DVD's I have recorded on my GoVideo player will not upload on my PC and play correctly. How Do I convert to use on my PC & the Corel Videostudio Pro x series software? I have a few that a frie
If this is a DVD Recorder, you must be sure that DVD -/+ discs are FINALIZED. The discs you've recorded should also be checked on another DVD player other than the one they were recorded on. If not finalized, they will play nowhere else but the recorder they were recorded on.
Aug 08, 2012 | GoVideo VR3845 DVD Recorder/VCR
My vcr tapes play too fast
If I remember correctly, VCR players had three speed settings. SP-short play, LP-Long play, and SLP- Super long play. The vcr is supposed to be able to tell what speed the tape was recorded at, thus playing it back at the correct speed. If your unit has lost the ability to sense the speed the tape was recorded then you will have to set the speed manually, if possible. Other than that I would have to say it's time to get a new vcr.
Feb 20, 2012 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How to record a vhs tape to dvd on a samsung 1080
Hello
1.The VHS/DVD player must have recording capabilities.
2 Connect both players to a television so that you can make sure you are recording the appropriate content. You can also monitor the speed at which the VHS is copying to DVD.
3. Place the VHS in the VHS player and the blank DVD in the DVD recorder. You will need to use your remote and go through the menu options to choose the correct format for recording. The formats should be clearly labeled and outlined in your instruction manual. Choose the option that will read something like "VHS to DVD." You may also have to choose recording speed, which varies per blank DVD that you purchase. Every player is different, and every menu will vary slightly. If you have questions, refer to you individual manual.
4. Select the option that works best for you and hit "Play" on the VHS player and "Record" on the DVD recorder. To play the finished DVD, you will select the playback option.
THANK YOU
Dec 14, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Device will not play previously recorded discs or record new info,but will play shop bought discs.on occasions it will display disc error. i am using new discs.
I Have had this same problem with DVD recorders. They sometimes will not play disc that were recorded on another player, you have to play these on the recorder that you used to make the recording. When recording you must finalize the discs to get them to play in other recorders, if they aren't finalized then the dvd wont recognize them as being recorded, there is no starting point set on the disc for the laser to pick up on. I have also ran into discs bought at the store that were not any good and I couldn't record on them, or when I did I would get the disc error message also. Try another brand of disc,say Memorex or Soney amd see if these will work, make sure they are compatible with the player, and they are the correct format for your player. There are 2 types DVD -R and DVD + R the + R work better on a wider range of players.
Nov 25, 2010 | Philips DVDR880 DVD Recorder
How do i connect dvd player to dvd recorder
you need a tri-color (red,white & yellow) rca cable wire w/ gold tips.....either on the front or back of dvd-rec ....connect wire to the in (line 1 or line 2) coming from the play out on the dvd-player....your dvd rec is still connected to the tv right...on the dvd rec using remote select line 1 or 2 which ever is connected...(test..by playing a dvd in the player..if you see the picture plus hear the audio this means its connected correctly and can be recorded)...note some Disney dvds are not recordable...hope this is helpful.............feel free to rate
Jun 14, 2009 | RCA DRC8300N DVD Recorder/VCR
Samsung DVD-R120, can I save what?s on a DVD-R that won?t play?
If it will not play either on the recorder it was recorded on or any other player, you need professional help retrieving the data. There are places where this can be done, but it will probably cost MANY times what the disc does.
Jan 21, 2009 | Samsung DVDR120 DVD Recorder
I HAVE A MAGNAVOX DVD RECORDER MWR10D6 AND I AM TRYING TO RECORD VHS TAPE FROM A VCR TO THE DVD RECORDER. CAN YOU HELP ME WITH THE CORRECT CORRECTIONS; NOTHING IS RECORDING
Play the video on your through your recorder if possible, then record it that way. It works for me. Just go to your watch tv setting and record it off channel three while the vcr plays the video.
Jan 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Dvd finalization
I turned off the Colby recorder then turned it back on and inserted the DVD and chose the edit button on the remote controller. The correct menu with the close and finalize choice became available.
May 26, 2008 | Coby DVDR1280 DVD Recorder/HDD Recorder
Playing recordable dvd
Your player may only be able to play DVD-format discs. Try converting the video with Nero or WinAvi or DVDFlick to true DVD format.
Feb 21, 2008 | Emerson EWD7003 DVD Player
Norcent Technologies DP1800 System Logo
Top Norcent Technologies Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Norcent Technologies Audio Player and Recorder Expert? Answer questions, earn points and help others
