Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Runs almost all the time. freezer freezes, unit just runs too much
    Champion:
  • 245 Answers
I would make sure your setting dials or buttons are set on the factory settings. If they are than this would be your thermistor located behind the access panel up top. This is the part that has a dial with a long flexible wire with plastic covering. This part tells the refrigerator when to turn on and turn off. I hope I helped you.
Posted on Sep 02, 2010
Westinghouse rs652 freezer not working
If the unit runs but not getting cold time for a new one.If it doesnt start posssibe thermostat problem.
Jan 15, 2016 | Westinghouse Refrigerators
Why does my freezer not freeze?
Sound like a typical low freon Issue. Check out our articular on recharging residential refrigerators and freezers
On Time Appliance
If it Helped follow us on our Google plus page.
On Time Appliance Google
Jun 29, 2015 | Freezers
Kelvinator fridge compressor running constantly, but freezer section barely freezing
CHECK THE CONDENSER COILS UNDER THE UNIT. THEY PROBABLY ARE DIRTY AND CANT REJECT THE HEAT.
Oct 18, 2012 | Kelvinator Refrigerators
Hotpoint HTR17BBRFRWW top freezer does real cold but bottom fridge stays at 52 or above. Coils clean and gaskets good, unit level and compressor runs quiet. What is obstruction between freezer and f
http://www.partselect.com/Schematics/GE/00113789i02.gif
look at number 304. Ice more than likely has formed and not letting air flow from the freezer to the fridge.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 03, 2012 | Hotpoint Refrigerators
My Electolux freezer freezes things at the top but not lower down, why? Also the top has a huge and rapid build up of ice crystals.
Sounds like you have lost some of the refrigerant charge. when this happens the cooling coils only freeze partway and the unit runs most of the time due to lost capacity.
Jun 22, 2011 | Electrolux Freezers
Freezer does not freeze
Check for Freon pressure and see if its low. you need professional help.
Jan 25, 2018 | GE Â 17.9 Cu. Ft. Top-Freezer...
Alesis dm5 drum module keeps freezing after 2 mins of playing
Not a lot of ideas for you, but IF it will restart right away it is probably at the end of the particular song memory you have selected. In other words, you may be playing a song performance rather than just a plain rhythm. A song runs for the number of measures it is programmed for, often around the two minutes you mention.
If the whole unit freezes and all panel controls are dead, then I want you to actually freeze the unit in your freezer and quickly try it and measure the time it continues to run. This is to determine if there is a heat related problem. If it runs longer, then you can isolate the problem with circuit cooler.
Sep 02, 2009 | Alesis Sr 16 Stereo Drum Machine
Freezer not freezing properly
You have a manual defrost freezer . Ice build up of over 1/2" can act like insulation on wires . If you have no frost build up , and runs constantly , then compressor or refrigerant leak is the problem . Advise to replace freezer . Only 2 parts on manual defrost freezer...compressor and cold control . Compressor will not run if bad cold control . If you have a leak , very expensive to have repaired .
Jul 10, 2009 | Whirlpool GD2SHGX Refrigerator
Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
May 30, 2009 | Refrigerators
Kenmore refrigerator freezer not freezing
Yes that is a proplem...when ever that compressor is running that fan motor should be running too.. also you evapurator fan motor should be running also
Aug 20, 2007 | Magic Chef CTB1722 Top Freezer...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
44 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
