Ducted air con. running too much water under - Heating & Cooling
  • Gary Davd
    Gary Davd May 11, 2010
    make some sense and repost your problem
Dirty filter or coil, check freon charge. sometimes its normal if your place is very humid
Posted on Aug 19, 2008
Water leaks under portable air con unit
Look for a crack on the water tank or a dried up gasket on the tank. Loose hose clamps can allow a leak as well.
Jan 04, 2014 | Heating & Cooling
My Vw golf TD auto air con. Baffles get stuck so no air can come through. Fan seems to be working ok., so does the air con itself. Mechanic having trouble working out how to fix, any help very welcome.
the baffels have foam arround the edges.
the foam breaks down and gets stuck all through out the duct systen.
try removing the all the flow vents and then blasting the duct system with compressed air,you could also try one of those "lint lizards" attached to a vaccume cleaner to try and get out all the loose foam floating arround the duct system.
Good luck,Gary
Oct 27, 2013 | Volkswagen Cars & Trucks
Burning plastic smell from under hood
You will need to check where the liquid is coming from, It may be anything from Air Con, Fuel, Transmission Fluid etc..
The fact you smell burning plastic could be 3 things..
1, Brake pads could smell and burn down if they are on too tight (Had this problem with a trailer). Hence when you apply the brakes it could be squirting brake fluid out due to too much pressure.
- Check brake fluid
2, If the smell and liquid is inside the car (front pass side) it could be the air ducts. Under the dashboard you have air ducts etc for the fans and in car cooling (brother had issue with this)
3, Whatever the fluid is, it could possibly drip onto something hot, unusual for liquid to smell like plastic though, Auto transmission oil smells like fish.
Best bet would be the brakes. Next time you smell it just smell in the wheel mag and see if you can smell it, check the engine fluids often and dont use A/C (Air Con) as that does drip fluid (normal). If it is the brakes smelling you will need to have the lines bled out, tyre places may be able to do this, and possibly new brake pads
Good luck
Oct 20, 2012 | 2007 Suzuki XL-7
Show me where the filter is located
dear sir /madam
please know what is type your air-con i mean widow type or split type or Central air conditioning's unit .if your air con is window type air conditioner then remove cover (grill) and find there is air filter if your air con split type of then open its cover there down side of cover there.is filter located
if air con is central cooling unit the find out your filter in duct side i mean air blower side where fresh cool air going to your room .
use this method i hope you will find solution of your problems
thank you
please vote!
Sep 06, 2010 | Heating & Cooling
Have lost my user manual for Fujitsu ducted air con model no AOT45LJBYL. Cannot find online please help
I just moved into an apartment with Fuji ducted air - no manual, and the control box wasn't set properly.
Perhaps this PDF manual will help you too.
http://www.fujitsugeneral.com/wired_remote_down.htm
Jan 10, 2010 | Fujitsu Heating & Cooling
Water is leaking from under glove compartment
water dripping from under the glove box area is usally a sign of water in the heating ducts. water runs down the windshield and goes under the cowel, then instead of draining, it some how enters the air intake for your heating system. Take off your wipers, and remove your cowel, you will be able to see the air intake (on the passangers side) and the reason why the water is being directed into it.
Sep 28, 2009 | 2005 Dodge Caravan
During heavy rain water flows over my feet! Where does it come from??
most vehicle have a rubber drain plugs on driver and passenger side under the carpet. keep in mind you don't want to get lots of water under your seat because the computer mod sit right under the seat, if it gets wet it will cost you big buck to replace. good way to check it, next time when you get the next oil change or get the car up in the air, ask the mechanic to look at the rubber drain plugs at the bottom of your car and see if it still there and in good condition. pulling and lifting the carpet its not good idea and lots of work. If the the floor drain plugs looks good then check sunroof if you have one, check the seal around the roof making sure its has a good seal; it may not have a good drain. The last resort will be the fresh air duct from outside in front of the car next to front windshield, which is leaking through the unit. good way to also check the problems is take the vehicle to the car wash using high pressure water gun and spray in it fresh air duct for minute or two and see if its leaking through. hope that help some good luck
Jul 10, 2009 | 1997 Audi A8
Climate control
You need a temperature control actuator..which mounts on the rh side of the central air con ducting under the dash.Remove the ducting panel on the rh side (3) bolts, then the glove box (2 bolts) then unclip the wiring harness connection box and push aside. Using flashlight look into the center at the central venelation ducting box, on the rh side there should be two raised bolt holes, where the actuator mounts over the white spindle shaft.
Apr 26, 2009 | 1998 Buick Park Avenue
Heating & Cooling Logo
48 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
