Question about KitchenAid KSRB25FKSS Side by Side Refrigerator
We just moved the fridge to paint behind it. However, afterward the fridge is just cool but, the freezer works great. We have the fridge on max cool and still just cool. I also don't notice any moving air in the fridge like you do in the freezer. Thoughts??
    Champion:
  • 245 Answers
I am not 100%, but there is an electronic door that allows cold air to pass through the freezer to the refrigerator.This is located in the refrigerator in the top left hand side. If you can here the fan in the freezer than you are probably have an electric door which is controlled by your thermostat. Make sure you set the thermostat back to the factory settings when you replace the evaporator fan electric door. I hope I helped you.
Posted on Sep 02, 2010
    Champion:
  • 246 Answers
I do not know about your specific issue but if you are ever looking to change the look of your appliances then check out this site www.applianceart.com
These guys have lots of options including stainless steel.
Posted on Feb 22, 2011
My kenmore 253 upright freezer/fridge is not cooling the fridge part correctly. It's cool but not cool enough to keep the food fresh. The freezer works well sometimes. And sometimes it seems that it's not...
Try this test. Set a window fan behind the fridge to constantly blow air across the lower coils at the floor. If the fridge works well after a while of this, then the lower fan on the fridge needs replaced. Sometimes though, after a while, the fan will finally start working again because the cycle has finally corrected itself with the test. Leave the window fan run on low for a few days before removing it. The hum you hear is the compressor moving the coolant and is supposed to do the hum sound. That's good. Now once the fridge is working, and you still have a good freezer section and not cool enough below in the fridge for you, there is a knob that sets the cool lower by opening flaps under the freezer to let more cold down to the fridge area. Set this knob to colder and the flaps will open more.
Nov 11, 2014 | Refrigerators
Drse663b
sounds like the automatic defrost system failed and if you removed the evap cover it would be blocked with frost.
Nov 29, 2013 | Amana Refrigerators
The freezer part is working good but the cooler side cools but not enough
the damper vent door between the freezer and fridge section isnt opening up to let cold air in from the freezer side to cool the fridge side,its behind a plastic grille near the top between the 2 compartments,there is also an evaporator fan near this and it also needs to be operating to move the cool air
May 24, 2011 | Jenn-Air JSD2789GES Side by Side...
LG FRIDGE,, fan not working or is thermostat faulty?
fan bad or not defrosting look for ice build up behind panel by fan
Oct 26, 2009 | LG Refrigerators
Freezer working but Fridge not cooling... Tried adjusting temp to max cool and nothing. Unblocked vents, still nothing... Pulled off back panel cover to vacuum and brush... still nothing... help??? In case...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Oct 26, 2009 | Amana ARB1917CSR Bottom Freezer...
What is the purpose of two temperature control nobs when there is a single compressor in my samsung 280 lts fridge
1.If this is only a fridge the one knob will be for the min and the other for the max.
max. : As soon as you switch the fridge on it will cool down the fridge to max cool down temp. example -2deg.
min. : As soon as the fridge reaches the max cool down temp and it had switch the compressor off, the fridge will start to warm up slowly, by the time it reaches the min allowed warming up temp, it will switch the compressor back on and do the cycle all over again.
2. If it is a fridge/freezer setup, the one knob will be for the fidge and the other for the freezer. If the temp in the freezer is fine a fan is activated and blows all the cool air to the fridge and controls the temp. by activating the fan.
Sep 06, 2009 | Refrigerators
Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Aug 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
Freezer is working but fridge is not cooling
is the evaporator fan (in the freezer) running? if not you cant move the cold air from the freezer too the fridge. also make sure the return air duct is not blocked. air moves from freezer, through fridge and back to freezer.
May 25, 2009 | Haier RRTG21PAA Refrigerator
Compressor working but Fridge and Freezer not cooling - Amana
It sounds like the same problem my brother is having with his. I took it apart and found that the fan that moves all the air for cooling is not working. This fan is behind the bottom panel in the freezer side, and sorry you do have to take everything out to get to it.
May 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
KitchenAid KSRB25FKSS Side by Side Refrigerator Logo
180 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
