On A magnavox ct270mw8 A shuts itself down after 3 secs
    Sergeant:
  • 252 Answers
You have a bad ceramic capacitor in the high voltage section of your TV. They are usually in parallel with other identical caps located beside a transformer. Notice that your TV has three of these circuits for each color gun. The best way to check these capacitors is to pull one leg of the caps out of the circuit board then test them with a Fluke Digital MM. Set your meter to capacitance and make sure that is on auto range. If one of these caps has a very low farad reading than all the rest this is your problem cap. What is happening is that when this cap is trying to build up to a certain voltage it cant. This is in turn causes a system overload and then your TV shuts down
Posted on Sep 02, 2010
When i press the on button, the first logo screeen comes in abt 7-10 secs then after 3-5 secs fan error appears on a blank screen and after another 2-3 secs it shuts down by itself. I cannot boot...
the problem is simple. you need to first change the fan for the processor. The pc goes off since the fan to cool the processor is faulty.........just to prevent damage to the processor. get a correct model, normally by checking the spare part number on the fan and try googling it up on the net. need me know if you need assistance in buying one.
good luck.
Apr 03, 2011 | Computers & Internet
Have a Magnavox model ct270mw8 27 in. 2007 dvd,vcr unit..It will run for a little while then go to shut down and sometimes before it goes to shut down,it will display the menu,then shutdown..Can unplug the...
the Vcr mech assy needs to be replaced it was a very common problem with this model try partsearch.com if they still have them avail around 70 bucks not an easy job to replace two cables have to be unsoldered and re attached to the new mech assy and the mode switch has to be set in the hole od the cam gear
Dec 11, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
TV shuts off after 5 seconds Magnavox CT270MW8
Open TV and notice if the VCR cartridge jumps (jitters) back and forth when you plug the TV in before it shuts down. If it does, there is a good chance you will have to replace the VCR mech on this unit (available from Andrews Electronics and maybe MCM electronics for $40-$50). This is a common problem on this unit. I work in a TV repair shop and see a lot of these come in for this reason.
Sep 28, 2009 | Televison & Video
I have an rca universal remote and a magnavox tv. cant find the instructions on how to program
try this, press and hold the tv button on your remote about 3 sec. light should stay on, then enter code, if it's a good entry light should shut off, then try to turn tv off. make sure your tv is on before trying this. If tv does shut off then you're done if not try other codes magnavox codes0062 0004 0009 0183 1133 0226 0288 0456 0008 0068 0075 0141
Feb 20, 2009 | RCA Universal Remote Control
Toshiba A60 shuts down in 3 seconds
Bios may be set wrong(fix by restoring default settings)
memory may be damaged(replace if true)
battery may be low and system shuts itself off(make sure battery is charged)
Drivers may be wrong(replace drivers in safe-mode)
Motherboard or other devices inside laptop may be loose and/or shorting.(Go to local computer fix-it shop or (open up laptop and check for loose connections which may void warranty.))
My guess is your bios needs resetting
Hope I am a help.
Feb 03, 2009 | Toshiba Satellite A60 Notebook
Magnavox TV Model CT270MW8
we were watching a dvd and the unit shut off. We can't get the DVD door to open. Is there anything we can do to get the DVD to open and start playing a DVD?
Aug 09, 2008 | Televison & Video
My TV shutting itself down
My TV is shutting off after you turn it on.Model #27MT5005D.
The light continue to blink, but thats it.
Dec 09, 2007 | Philips Magnavox 27MS343S 27" TV
White Screen w/ White Lines, Sound On, Turns off after 2 or 3 secs.
Hi If you mean thin white lines, this is is an indication of a problem in the Horizontal Drive ckt. most likely the Damper Diode has opened or shorted, this would cause the visual symptom and then the set would shut down, unfortunately this is a problem best left to a qualified technician to repair, hope this helps.
Apr 12, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
