Question about Viking Kitchen Ranges
When we turn the oven on the ignitor keeps making a Clicking sound like it is trying to keep igniting
  • Viking Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 02, 2010
My becko gas cooker is new and when i turn the oven on the hob ignitors keep clicking what do i do pls
So when you are turning the oven on, It is the same process as your cooktop. you turn the knob to ignite( so its clicking) and once it catches fire you back off the knob to adjust your flame. the oven is the same. its just bthat all your igniters will want to light at the same time, but gas is only being fed to the location of whatever knob your turning. omnce oven is lit, turn back the knob to dedired temp setting. hope that amsers your question. good luck. Or, if no gas is getting to the location, make sure the valve for your gas is on.
Jun 20, 2015 | Kitchen Ranges
My maytag mgr5729adw gas range oven omits a strong gas smell when attempting to preheat. Sometimes it heats sometimes it doesn't but use to get a small boom when igniting. Ignitor still glows oran
see the next steps and proceed with common sense: God bless you
Main Control / Oven Switch
The main control or oven switch may have failed. You will need to identify the wires from the switch/control that lead to the igniter that is clicking. These wires may pass through the spark module and change colors. Refer to the wiring diagram or tech sheet. If you have power leaving the switch/ control when in the off position replace the switch /control. Manual switches can be tested with an ohmeter.
Spark Module / Igniter Module
If your oven igniter keeps clicking the igniter module or spark module is the likely problem. First be sure the igniter is clean and the surrounding contact points are clean. Make sure power is off when cleaning. If the oven keeps clicking after it's cleaned and the oven switch / control checks good replace the spark module.
Jul 26, 2012 | Kitchen Ranges
Our Honeywell programable thermostat keeps clicking and furnace isn't turning on. Changed the batteries but still doing the same thing. Suggestions?
Clicking is the sound of the ignitor trying to ignit the gas. Check to make sure the gas valve is turned on, the gas **** is in the on posistion. If they are you will need to replace the gas valve.
Feb 02, 2011 | Honeywell Programmable Thermostat Heater
My indesit gas cooker's igniters keep clicking
Hi yes it could be that if it only just done this leave it off you can still use the top the heat while cooking should dry it out.
Oct 10, 2009 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Electronic ignitor does not recognize that flame is on thus does not stop clicking
A generic troubleshooting response would be...... if the burner won't stay on, either the igniter or the ignition module (or both) are bad. If the burner ignites and stays on but the spark module keeps trying to ignite, the module must be bad.
Sep 14, 2009 | DCS Microwave Ovens
Hi, I replaced the right side ignitor module and now the ignitors spark vigorously and the burners light but the ignitors won't spot sparking and sometimes keep sparking several seconds after I turn off...
There are a few things to check for. Make sure the electrode ( the small metal piece that the spark comes off from ) is clean and the holes in the burner are clean, use a pin or paper clip to clean out the burner holes and NOT a tooth pick as these can break off and make things worse. The next thing to check for are theignition switches under the surface control knobs, the switches can twist and break and keep the spark module on and the spark keeps "clicking" even when the burner is light. If every thing looks good, you may have a bad spark module, replace it. Sometimes cleaning can get moisture into the surface switches, try drying them with an hair dryer to see of this will help.
thanks.keep updated and please do accept the solution.
Sep 18, 2009 | Viking 30" Professional Select Built-in...
Ignitors keep clicking
oven will not come on, where's electric ignitor.
Nov 21, 2008 | Tappan 30IN ELEC IGNa Oven
When i turn on the oven the top hobs keep clicking on my canon cooker
Hello Brian
Welcome to Fixya.
You said, when you turn on the oven the top knobs keep clicking on my canon cooker.
If you mean the electronic ignition keeps clicking when you turn the oven, It sounds like one of the switches that is controlled by the knobs, is stuck and malfunctioning! It sounds like it needs to be replaced.
There are 5 electronic igniter's on a 4 burner gas range, and the fifth is in the oven.
Let me know how you do.
Please remember to leave a rating when you finish.
Thank You, Huuum
Oct 02, 2008 | Kitchen Ranges
Kitchen Ranges Logo
301 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
