Question about Daewoo WM1010CC Microwave Oven
Wont heat up. comes on turns, etc just no heat
  • Daewoo Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Sep 02, 2010
Kenmore microwave 72169122010 turns on but wont heat or spin turntable?
Door sw 'turn on and push up and down on the door it make come on
Oct 15, 2014 | Microwave Ovens
Microwave wont heat
We would need to know the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc.
Please post a new help request with that and more detailed symptoms, such as when it occurs.
When you hit "Start" to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Apr 15, 2013 | Sharp Carousel 1.5 cu. ft. Countertop...
The inside light turns on the turntable do not comes on appears to work but it wont heat
If the table does not turn it may not heat--A lot of these have a lever switch that is engaged when door closes--if it is not engaged no heat and no table movement---some actually break loose where they are mounted just inside the door frame (have to take apart unit to see them).
This happens as with door being closed often and or hard they can come loose. Its a safety switch to prevent use of the oven with the door open.
Jun 15, 2012 | LG Microwave Ovens
I have a kenmore stove whose burners wont light. oven works fine. burners will spark but no gas comes out. recently I turned off the power to the stove by turning the fuse off. what do I need to do to get...
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
Apr 12, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
Screen keeps coming up press any key i do and it says demo model wont heat defrost etc
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
In most cases, y
ou can download your Panasonic owner's manual here.
Jan 09, 2010 | Panasonic Microwave Ovens
Russell hobbs microwave turntable wont turn
Is there an option via the Help or Custom Help to turn the turntable off and off?
This feature is common in over the range models.
Otherwise, it may be a bad motor.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand: http://www.youtube.com/watch?v=rPSWi_z7M58
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven, as you're looking up from the stove top.
Please write back with your model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 20, 2008 | Microwave Ovens
Microwave turns on, but no heat or turntable movement
The problem is that the magnatron is not getting power. Chance is that if could be a bolwn fuse inside the unit. If the fuse don't fix it then that leaves the charging diode, capacitor or the magnatron, or high voltage xformer of which without technical epertize I would not recomend attempting to replace. good luck
May 14, 2008 | Hotpoint RVM1635 Microwave Oven
GE spacemaker xl1800
more than likely the fuse has blown onthe magnatron it is the button looking thing on the magnatron with two wires. there are 2 of these one is on the magnatron the other is above the heat box test these for open. if open replace. if good then replace the magnatron.
May 02, 2008 | Microwave Ovens
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Daewoo WM1010CC Microwave Oven Logo
353 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
